Electronic Igniton
Old Apr 30, 2018 | 08:22 PM
roadawg1122's Avatar
roadawg1122
Default Electronic Igniton
Looking for advise on electronic ignition conversion for my 74 350 cid
Old Apr 30, 2018 | 09:22 PM
drwet's Avatar
drwet
Easiest solution is to swap in an HEI. Factory or good quality aftermarket. If original appearance is important to you, look at the Pertronix conversion.
Old Apr 30, 2018 | 09:27 PM
roadawg1122
Default Thanks
Thank you drwet. Appreciate the advise. I would like to keep the original look as the car is all original, numbers matching.
Old Apr 30, 2018 | 10:43 PM
riverracer au's Avatar
riverracer au
nothing wrong with a "good" set of points when set and adjusted properly.
i had the "Breakerless SE" one wire setup, had my dissy rebuilt and have gone back to points.
Old May 1, 2018 | 12:30 AM
Iceaxe's Avatar
Iceaxe
I went with the Breakerless SE for several reasons. It's a 15 minute swap, retains stock appearance, no running of extra wires required, can swap back to points in 15 minutes, and its dependable. YMMV
Old May 1, 2018 | 07:14 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Pertronix
Old May 1, 2018 | 08:40 AM
74Ken's Avatar
74Ken
Pertronix and a new coil in my 74 350.
Can't stand points and will be replacing the carb maybe next year with Fi-Tech.
There are some things from the old days I can't stand. Others I love
Old May 1, 2018 | 09:17 AM
drwet's Avatar
drwet
I put a Pertronix on my '66 and ran it that way for 20 years without ever looking at it. In those days the Pertronix required two wires, so the appearance wasn't perfect. I understand they have since come up with a one wire system that is undetectable without removing the distributor cap.
Old May 1, 2018 | 09:55 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Pertronix
Old May 1, 2018 | 02:50 PM
roadawg1122
Default Thanks
Thanks for the advice. Sounds like the way to go .Any suggestions on a coil to go with it?
Old May 1, 2018 | 03:07 PM
MelWff's Avatar
MelWff
they make a matching coil to go with it
Old May 1, 2018 | 03:30 PM
roadawg1122
Thanks Mel. Will look into it.
Old May 3, 2018 | 09:03 AM
kansas123's Avatar
kansas123
Petronix!
To Electronic Igniton
