Ceramic coated headers got really hot
Old May 3, 2018 | 10:07 PM
jr73's Avatar
jr73
Default Ceramic coated headers got really hot
Started up my new motor and with a combination of too lean of a carb setting and timing on the retarded side she got real hot real fast. four of my header tubes turned a dull chaulky finish on the upper elbows and it's rough to the touch.
Do you think the coating burned off?
Is there anything I can do to fix this?
Is Hooker any good at refunds?
Old May 3, 2018 | 10:31 PM
cagotzmann's Avatar
cagotzmann
Got some pictures. ?
Proper ceramic coated headers don't do that just setting up the carb.
Mine didn't do anything like that even after many track days. Mine measured 590 Degrees F after track sessions.
Old May 3, 2018 | 11:18 PM
jr73's Avatar
jr73
this is after I tried to clean them up a little with a stainless wire brush
It's the two center tubes.
Old May 4, 2018 | 03:47 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Mine did that after track duty and they are Jet Hot coated. Engine was dyno tuned and the heads have been off since then and there was no evidence of engine damage. That was years ago. T
Old May 4, 2018 | 05:44 PM
C3 4ME's Avatar
C3 4ME
FWIW, mine started out shiny almost like chrome and dulled over time to the dull silver that you show on your tubes. I accepted that was what they were supposed to do, and haven't tried to polish them back to shiny.
Old May 4, 2018 | 05:51 PM
jr73's Avatar
jr73
I bought a used set for my 68 Camaro and they are also Hookers and still look amazing 10 years later.
Old May 5, 2018 | 08:14 AM
Heus's Avatar
Heus
My Dougs ceramic coated headers on my 78 got too hot when I was setting up my new crate motor. The middle two got slightly red hot. They turned that chalky color but have not gotten worse three years since.
Old May 5, 2018 | 11:35 AM
jr73's Avatar
jr73
Anyone ever contact the manufacturers?
Wonder how they respond to these issues.
Old May 5, 2018 | 06:01 PM
metal tech's Avatar
metal tech
I hate to say it but, most mfgr's have a statement about not using coated headers while breaking in a new engine. The added heat from lean & timing being off probably only dulled the surface. If you can live with that then you should be ok. If not, I don't know if the mfgr will swap you a new set or not.
Old May 6, 2018 | 02:06 AM
jr73's Avatar
jr73
I literally just read that today. The Hooker info said the headers must go through a few normal heat cycles to cure and NOT to use them to break in a motor. Why dont guys read instructions?
Old May 6, 2018 | 03:25 AM
Sunstroked's Avatar
Sunstroked
Well, how many of us have spare headers laying around just for break in? Im running Dougs ceramic coated, Ive broken in 2 engines with these installed. Not "shiny" but they are fine. No rust, still silver. I remember my old headers from back in the day, rust, burned paint, looked awful within months. Stainless turn blue, they just do. Silver ceramic is about as good as they get.
To Ceramic coated headers got really hot
