Build / Line Ticket
6th Gear
Build / Line Ticket
I had a 1965 International 1100D Pick up truck where I was able to find an original copy of the original line ticket that was used to build the truck. Being the IH family is rather small compared to GM/Chrysler and that 4 letter word that starts with an "F" that Mom never told me to say, I was wondering if anyone knows of a web site, or even a place to send a snail mail request to, to find an original build ticket for my 1974 C3? At the moment it's mildly customized, and I am not entirely sure on going back to all original only because the color that it is right now is the Dark Brown...... and I am not much of a fan of that color. However the price was right on it so.
Any suggestions or help there? I don't get back on here much so a PM might be best?
Received 2,878 Likes
Hi 74T,
Welcome!
First Post!
I'm afraid there's no source for a duplicate of the original 'Corvette Order Copy' for your 74 Corvette.
Nor is there a source for the information that it contained.
One of the Corvette Order Copies was glued to the top of the gas tank as the chassis made it's way along the assembly line and another copy was often placed behind the dash... sometimes between the tachometer and speedometer or behind the radio.
There might be a chance that one or the other might still be in place.
If you check and find one be especially careful handling it because the paper has typically become quite fragile... especially the one on the tank.
I wish there were better news but there's not.
Not having the sheet won't diminish the fun you can have with your 74 though!
Regards,
Alan
A typical tank sheet location... but sometimes it's on the left side of the tank.
The sort of information the sheet contains including the options the car was ordered with.
Welcome!
First Post!
Regards,
Alan
6th Gear
Hi 74T,
Welcome!
First Post!
I'm afraid there's no source for a duplicate the original 'Corvette Order Copy' for your 74 Corvette.
Nor is there a source for that information that it contained.
Regards,
Alan
Welcome!
First Post!
Regards,
Alan
Received 1,469 Likes
Cruise-In II Veteran
FWIW: the time/build code for your car is in the upper right corner of the trim tag. The date is the month and day your car reached the station on the assembly line where the tag was attached. Your car may not have been completed on that day, but, at the least, you know it was in the works on the trim tag date.
In addition to the dash or tank, buildsheets have been found under the jack, carpet but these finds are the exception rather than the rule.
Hope this helps!
