RetroSound Long Beach Radio?
Here's a pic of my RetroSound Hermosa radio, with 53-73 **** Set (Chrome with black center), and chrome bezel in my 69.
I think it looks nice, and sounds 'ok', but if I were doing it again, I might consider mounting some kind of remote control player/receiver behind the seats instead, and just use the remote (and leave the stock radio in the dash). Two reasons: the display is totally useless during the day (especially in a vert with the top down), and I think the sound is kind of 'tinny' (I'll probably add an amp and subwoofer the next time I have the dash apart). For the price, I expected the display to definitely be brighter.
Pros: compact size, USB dongle connector for playing MP3 music (at least the Hermosa has USB, not sure about the other models).
And here's a pic of everything that was 'in the box':
Don't know anything specifically about that brand but it looks suspiciously like the Custom Autosound "retro" type radio I had recently. It was way overpriced for what it was, $300+, professionally installed. Audio and reception were sub-par. Started giving me problems within a year and completely died at about two years. Warranty expired. I bit the bullet and cut the panel to fit a nice modern Alpine at about half the price. Couldn't be happier.
I did a Retro Sound in my 71. As said above it needs help to get rid of the "tinny" sound.
Needs amp and sub woofer. I had dash and kick panel speakers. Really needs a couple of 6x9's in the back.
Custom Auto Sound is junk as far as I'm concerned. Had two and they both had problems. Display went bad. Push buttons stopped working.
Mine has kick panel speakers and 6x9's in the back (in a custom built box) - still needs the subwoofer. Luckily, I built the box with that possibility in mind - but only had room for a 6" subwoofer unless I took out the soft-top...
I used speakers from the local stereo home audio guy. I believe they were JL. I didn't add a amp or sub woofer. Per the local stereo guy the amps today are very small and can be hid up under the dash.
On my 68 C10 project I'm using two 4" JL speakers up in the dash and two 6x9" in the corners of the cab. He said let's hear before we start adding stuff.
I was going to get one so i wouldnt have to cut my dash.
But the more i looked into them, the less i was impressed. THey are really expensive for the little features they have. beside the faceplate they all seem to be universal. and need to be built to fit your car. requires adjusting cheapy brackets, and ***** that need to be connceted. Ive read many issues with the ***** not working properly after a few months use. The interface looks difficult to navigate especially with the tiny screen and lack of buttons.
You can buy better Din radios with more features and power for 80$. So what im gonna do is get regular DIN bluetooth headunit with multiple usb. bluetooth mic, input outputs etc. and mount it in the storage compartment with and underdash kit. and mount the amp next to it.(or built into a speaker box). run a usb to charge my phone through the ashtray door. and run all wires to the back.\
I will have my original radio as a dummy. connect to back headunit via bluetooth adjust volume on device etc. can just reach over behind rear seat to headunit if i need to. get nice speakers amp with money saved. easier to wire everything back therem than having the retrosound wires going to back then to front.
