78 No turn signals
Old May 17, 2018 | 12:29 PM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
Default 78 No turn signals
New Brake light switch
Brake lights work fine
Hazards work fine
All the bulb blink and marker lights work
Turn signal switch in the column?
I tried a new flasher
Old May 17, 2018 | 12:46 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
That would be the first place I looked. What year and do you have a wiring diagram?
Old May 17, 2018 | 01:21 PM
Bikespace's Avatar
Bikespace
LED bulbs? If so, you might need to swap the direction current flows through the (LED) flasher relay.
I had a broken ground lead inside a rear bulb socket. I replaced all of the sockets, and that fixed a similar problem.
Old May 17, 2018 | 02:16 PM
csherman's Avatar
csherman
1978 - I do have a wiring diagram -
Old May 17, 2018 | 02:17 PM
csherman's Avatar
csherman
- All regular bulbs and they all work - No LED
Old May 17, 2018 | 02:50 PM
DB Cooper's Avatar
DB Cooper
It would be a good idea to check for power on the harmonica connector before considering a new turn signal switch. Pretty easy to check for power at the supply line, and power out on the turn signal wires. Nothing needs to be unplugged, the pins in the plug are reachable with the test leads.
Old May 17, 2018 | 03:08 PM
csherman's Avatar
csherman
I will check !
Old Jun 7, 2018 | 07:11 PM
csherman's Avatar
csherman
Update and need some advise
Hazards work - all the bulbs flash
Hazard flasher in the fuse box on the firewall works fine
Turn signals do not work
Anti theft does not work
Flasher in the center console replaced with a known good one
Does the anti theft work with the turn signals?
Do I need I new anti theft switch/relay
I will start testing power
Old Jun 7, 2018 | 07:51 PM
Peterbuilt's Avatar
Peterbuilt
On your '78 is the turn signal flasher behind the glove box?
Old Jun 8, 2018 | 08:52 AM
csherman's Avatar
csherman
it is in the center console
also with the anti theft relay
I ordered a new relay
Hope that fixes the issue
It is very strange because the t signals were working.......
Old Jun 8, 2018 | 04:42 PM
csherman's Avatar
csherman
So ......
Peterbuilt and DUB are correct
The t signal flasher is under the glove box
So.... I reach up and pull the wiring down
The pink and purple wire are taped to an Orange box
and guess what......
There is no flasher in the pigtail
WTH
Just a reminder to check the simple things and I learned there are three flashers in the car
1 for the hazards in the fuse box on the firewall
1 for the anti theft in the center console
1 for the t signals
Guys - thanks
DUB - thanks a million
Now - next task - fix the anti theft and off to Indy we go
To 78 No turn signals
