74 fuel guage issue
Old May 19, 2018 | 12:21 PM
KMCAMPBELL's Avatar
KMCAMPBELL
Default 74 fuel guage issue
The fuel sending unit has 23 ohms and moves when I manually lift the float. Wires, ground and tan connect to the fuel guage. 12 volts at the guage cluster. When I manually move the guage needle on the cluster and turn on the key, it will go from empty to full over hard on the needle stop. So all the parts work. Why doesn’t the guage read correctly?
Old May 19, 2018 | 12:22 PM
KMCAMPBELL's Avatar
KMCAMPBELL
Checking to see how the answers come in
Old May 19, 2018 | 06:47 PM
DUB's Avatar
DUB
Your sending unit should go from basically '0' to 90 ohms. I have seen them to to like 110 ohms...but you get the point.
I do not know how you are testing this or your set-up. But I can check the sending unit out of the car to see if the sending unit is fine.
Depending on the year model. I can check them while they are still installed in the fuel tank.
DUB
Old May 19, 2018 | 08:55 PM
KMCAMPBELL's Avatar
KMCAMPBELL
DUB
how would I test the guage?
Old May 20, 2018 | 02:49 AM
oVoSanto's Avatar
oVoSanto
You could connect an appropriate potentiometer (90 ohms) instead of the sending unit. Maybe you will find a 100 ohms potentiometer because is a more commercial value. But it's ok for the test.
Old May 20, 2018 | 10:56 AM
DUB's Avatar
DUB
IF the sending unit checks out as I described. IT can be used.
Because going out and getting another tool that will obviously do the same as the GOOD sending unit...is kinda insane.
The gauge is only going to do what it is being told to do from the sending unit...or the tool that you gout and buy.
NOW..if your sending unit is NOT GOOD...that may be your problem.
DUB
To 74 fuel guage issue
