1982 failed Cailifornia emmisions
Old May 19, 2018 | 01:19 PM
ml258's Avatar
ml258
Default 1982 failed Cailifornia emmisions
Recently moved to California and took my 1982 to smog today and it failed. The car is all original 43000 miles. Runs great no codes etc. Everything is original including the cat converter. Doing some research and my engine code is zba which is not a California compliant emmisions code zbc and zbn are. Does this mean I will not be able to pass California emmisions?
Old May 19, 2018 | 01:36 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
what did it fail on?
Old May 19, 2018 | 01:44 PM
toddalin's Avatar
toddalin
You need to contact a "referee" and get their take on it.
Worst/(best) case scenario is that you end up updating the engine to a more modern version ensuring that you take all the required smog equipment associated with that engine (think LS). This is an acceptable alternative, but again, talk to the referee first.
Old May 19, 2018 | 01:52 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Before going any further, you need to understand why you failed. Emissions? Missing equipment? Obviously each has a different fix.
Pure speculation, but I’d guess it’s the cat if the car is running well. The stock cats perform very poorly.
Old May 19, 2018 | 02:06 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
it is all speculation until the reason why.
when getting a smog;
engine should have clean oil
new filters
timing and idle set to spec on sticker
car must be hot.
the cat conv must be hot.
always drive car on freeway to get it hot.
don't let it cool while waiting turn for sniff.
Old May 19, 2018 | 02:20 PM
carriljc's Avatar
carriljc
Post your results. Redact whatever you don't want out publicly. Some folks have been dealing with this for 30+ years. There already allowances for non-california cars.
Old May 19, 2018 | 02:21 PM
ml258's Avatar
ml258
All original equipment was installed and the engine was hot. It failed CO% GP max is 2.43 and it measured at 5.69. Thanks
Old May 19, 2018 | 02:25 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
too rich
air filter
02 sensor
map
throttle pos
Old May 19, 2018 | 02:27 PM
carriljc's Avatar
carriljc
Here is a couple of generic lists for Hi CO.
https://www.smogtips.com/failed-high...onoxide-CO.cfm
http://www.auto-repair-help.com/auto...st_failure.php
Was that failure at Idle or at Speed? Hope that makes sense.
Old May 19, 2018 | 02:34 PM
Goody's Avatar
Goody
My guess is you'll see that it failed for the NOX count. There are many reasons an older car will fail for this reason, some are solved by a new modern 3way catalytic converter. Just keep in mind that you'll need to source a cat that is CARB approved (these are referred to as triple types, instead of the 49 state double types). I think Magnaflow makes one.
Before you buy any parts or pay for repairs you should try a few things first.
Did you fail at a TEST only station or a TEST and Repair? Lets assume you do not have a vacuum leak or exhaust leak, the smog pump is working and the EGR system is fine as well. Ensure car gets up to temp by driving it at freeway speeds for 20 mins or so. Oil was changed recently, filters are fresh, timing is spot on per the sticker.
There is a reason that chevy only sold the 305 engine cars in California instead of 350 across the board, because of emissions. But this was back then when the tech wasn't as good. Reason why a removable 3way cat might be the best use of your money. Still need to make sure the engine is fine before the investment.
Seeking the referee might be the best idea to start with but don't expect too much help.
Old May 19, 2018 | 02:45 PM
Goody's Avatar
Goody
See if you can get a reading from the O2 sensor. It may be lazy or bad.
Not sure if there are any adjustments that can be made to the Crossfire system. Research here will answer that question. Perform a complete tune-up before the retest.
Old May 19, 2018 | 02:51 PM
zwede's Avatar
zwede
First things first: You were wondering if your car can ever pass CA smog. Since you failed with 5% CO, the answer is yes. 5% CO is not normal at all. Even a hot-rodded car with no emissions controls at all can easily be tuned below 2% CO.
The #1 suspect with 5% CO would be the O2 sensor. Another possibility is the coolant temp sensor. I believe these early cars had 2 sensors, one for the gauge and one for the ECU. So the ECU sensor can be bad and the ECU thinks the motor is cold, running it rich. And this can be the case even though the gauge is working normally.
This is a crossfire TBI, I take it? If so also look down the throttle bodies after cycling the ignition (engine off) and look for leaking injectors.
Edit: Running rich for while will have finished off the catalytic converter (if it wasn't mostly dead already from age). Once you have the rich condition fixed, consider replacing the cat. It will further clean the emissions, but most of all you'll find a lot of power that was missing.
Old May 19, 2018 | 02:56 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
02 sensors are cheap.
he is basically running rich.
temp sensor could be saying engine is cold.
don't know the op's skill set but nothing that can't be tracked down.
Old May 19, 2018 | 03:06 PM
carriljc's Avatar
carriljc
If everything is stock, then I don't see the the referee doing you much good.... other than to tell you to fix stuff.
Old May 19, 2018 | 03:24 PM
derekderek's Avatar
derekderek
Dont need a ref, you need to go back with the CO and HC in spec. EGR, O2, temp, everything has to be right. Any check engine light? What codes?
Old May 19, 2018 | 07:43 PM
Mr D.'s Avatar
Mr D.
Mistake #1
Old May 19, 2018 | 07:47 PM
derekderek's Avatar
derekderek
Bought historic plates in Jersey to avoid emissions. Then found out NJ doesn't bother with emissions on anything pre-OBD2.
To 1982 failed Cailifornia emmisions
Old May 20, 2018 | 06:56 PM
gotgame's Avatar
gotgame
Where abouts in California are you? I know a couple mechanics in southern California who are very good with c3 and also smog.
Old May 20, 2018 | 08:46 PM
carriljc's Avatar
carriljc
Does anybody make a code reader/scanner for an 82 corvette? If I had just bought an 82, then I'd probably be wanting one.....
Old May 20, 2018 | 09:24 PM
bradleyb66's Avatar
bradleyb66
Welcome to California. You maybe already did this, but make sure that the smog tech KNOWS that it is a federal emissions car. My 79 is a federal car (relocated to California at some previous time). I only have to pass visual and specs for Federal, not CA (ie, 79 federal did not have an air pump). Your emissions label for an 82 should have a code CCW for federal (CCX is CA). If your label is not readable, the tech might have just looked up the CA code...
