fuel pump corvette c3 1982
Old Jul 3, 2018 | 05:27 AM
Dany025's Avatar
Dany025
I need a diagnostic tool to test?
j'ai besoin d'un outil de diagnostic pour faire les test ?
thanks for help me
Old Jul 3, 2018 | 09:28 AM
Lakeside49's Avatar
Lakeside49
You only need a paper clip bent into a “U”.
Insert both ends into their proper holes as instructed in the shop manual, then turn on the key (without starting the car) and then you will count the dash light pulses as explained in the manual.
Old Jul 3, 2018 | 04:01 PM
Dany025's Avatar
Dany025
OK I test when I have to go up the meters
OK je test quand j'aurai monter les compteurs
Old Jul 13, 2018 | 06:42 PM
Dany025's Avatar
Dany025
Hi;
Are you sure there is no need for this piece on the new kit?
Vous êtes sur qu'il n'y a plus besoin de cette pièce sur le nouveau kit ?
Old Jul 13, 2018 | 10:38 PM
Lakeside49's Avatar
Lakeside49
I am 100% certain that it has zero effect on the performance of your fuel pump. It is a radio noise supressor and since current design fuel pumps do not generate AM radio noise they are not necessary.
have you run the ECM fault code test using a paper clip as described in the shop manual? It is very easy. You are missing prime summer driving time with your beautiful classic car.
Old Jul 14, 2018 | 05:08 AM
Dany025's Avatar
Dany025
Thank you very much for your clarification.
I'm going to work on the corvette today, I'm going to do the tests
Merci beaucoup pour vos précisions.
Je vais travailler sur la corvette aujourd'hui, je vais faire les tests
Old Jul 14, 2018 | 02:52 PM
Dany025's Avatar
Dany025
I did the ECU and for 20 minutes I only have:
(Flash) Flash Flash (long pause), Flash (pause) Flash Flash (long pause), Flash (pause) Flash Flash (long pause)
The car was no longer starting, I opened the pump relay I moved a little contact and it starts, I will order a new relay.
J'ai fais le tets ECU et pendant 20 mn je n'ai que çà:
(Flash (pause) Flash Flash (long pause), Flash (pause) Flash Flash (long pause), Flash (pause) Flash Flash (long pause)
La voiture ne démarrait plus, j'ai ouvert le relais de pompe j'ai bougé un peu les contact et elle démarre, je vais commander un nouveau relais.
Old Aug 1, 2018 | 08:25 AM
Dany025's Avatar
Dany025
Hello
Hello
I changed the fuel pump relay, but I still have a problem.
The first start takes 10 seconds, then it starts right away.
I do not understand what is happening
j'ai changé le relais de pompe à carburant, mais j'ai toujours un problème.
Le premier démarrage il faut 10 secondes, ensuite elle démarre tout de suite.
Je ne comprends pas ce qui se passe
Old Aug 9, 2018 | 03:11 PM
Dany025's Avatar
Dany025
The fault was solved, the brown wire of the pump relay that had been cut and soldered was not fonctionne, I pulled the harness and redid the wiring.
La panne est résolue, le fil marron du relais de pompe qui avait été coupé et ressoudé, était HS, j'ai sortie le faisceau et refait le câblage.
many thanks for your help
Old Aug 9, 2018 | 03:36 PM
derekderek's Avatar
derekderek
What is HS? French for Bubbafied?
Old Aug 9, 2018 | 05:23 PM
Dany025's Avatar
Dany025
HS in french is not fonctionne
Old Aug 9, 2018 | 05:45 PM
Lakeside49's Avatar
Lakeside49
Well done, Dan
Old Aug 10, 2018 | 02:53 AM
  #33
Dany025's Avatar
Dany025
Many thanks Lakeside
