Slow window
Old May 23, 2018 | 06:05 PM
grumpy73's Avatar
grumpy73
Default Slow window
My power windows, on my 73, go down fine but going up is a struggle, have to help one by pulling it up. I have lubed the regulator and tracts. Am I looking at motors going bad? Is there a test to tell if they are the issue.
Old May 23, 2018 | 06:11 PM
TimAT's Avatar
TimAT
Check the ground system to the motors- it is very possible the motor(s) are just getting tired too. The rollers may also be stuck/frozen.
I have manual windows (69) and had to literally "chip" the old grease out of the tracks it was so hard.
Old May 23, 2018 | 08:57 PM
drwet's Avatar
drwet
I suspect your springs are broken.
Old May 24, 2018 | 09:19 AM
DUB's Avatar
DUB
I would also agree that it is likely that the spring on your regulator that aid in lifting the glass is broken...or...you have a dirty armature in your motor.
Or both.
DUB
To Slow window
