No power at all
Old May 25, 2018 | 02:14 PM
my70vette's Avatar
my70vette
6th Gear
Default No power at all
I have no power at all when I turn the key. I bought a brand new battery and still nothing. I was told the ignition switch but before I go any further I want to get some opinions. Can it be a burnt fuse?
Old May 25, 2018 | 03:12 PM
DB Cooper's Avatar
DB Cooper
First step is to make sure the negative batt cable is making good contact where it's bolted to the frame.
Old May 25, 2018 | 06:36 PM
DUB's Avatar
DUB
I am assuming that you own a 1970 Corvette??? You did not state the year model in your thread.
I am not meaning to insult you.
But how well versed are you in automotive repair and do you have the tools needed to find this problem....such as a DC voltmeter.
Do you have a wiring diagram for your car and know how to read circuits???
Check to see if you have power on the buss bar on your horn relay if it is a 1970. We will start there.
DUB
Old May 25, 2018 | 09:25 PM
BlueL82's Avatar
BlueL82
Fusible links at the starter? Had the same problem with mine. Another time it was my nuetral safety switch.
To No power at all
