1977 Corvette Flashers
I checked this a few weeks ago and am sure it was the 4-way flashers blinking on/off rapidly I'm sure probably needs a new flasher. I do have most of the interior apart trying to repair the wire and plug in the clutch safety switch (what a $%&&&*&%$#^) task that is and I.m also reinstalling the original factory AC Delco AM-FM 8- Track Stereo trying to hunt down the harness plugs for the radio.
As I stated the interior is apart where will I find and where to locate the 4-way flasher and while I'm at it I might as well replace the turning signal flasher would I be looking for two different flashers or are they both in one flasher
Thanks for your time and help
Th first pic is where your hazard flasher is!
Second and third is the turn signal flasher , mine had a resistor on it !
It was just above the passenger kick panel and behind the passenger lower dash pad !
Thanks to bmotojoe for the great diagram of the fuse block !
