hot water valve
Old May 28, 2018 | 03:22 PM
teamo's Avatar
teamo
Default hot water valve
My 1975 does not have the heater core hot water shutoff valve. Did they all come with them or was it only on certain cars. Can't find any info in the restoration guide.
Old May 28, 2018 | 05:15 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
This one is plastic https://www.oreillyauto.com/detail/b...ol+Valve&pos=0
This one is metal https://www.ebay.com/itm/HVAC-Heater...IAAOSwb~Ja2MVT
Old May 28, 2018 | 10:05 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you go to your assembly manual, on UPC b01-b12 sheet 69 you'll see the hot water shut off valve. It's actually on page 129.
Old May 28, 2018 | 10:44 PM
gsimon767's Avatar
gsimon767
75s with AC did not come with the shut off valve. Not sure about non AC cars. It is odd that they did not have them. My guess is that the vacuum switch for the exhaust crossover diverter and the AC compressor Used up the space for the shut off valve so the engineers just omitted it.
Old May 29, 2018 | 12:21 AM
derekderek's Avatar
derekderek
So they put in AC and made it fight the heater all summer? Heads up organization. Just a question of what they got their heads up...
Old May 29, 2018 | 03:19 PM
0Willcox Corvette
Former Vendor
It is odd... because I was at home and all I have there is the original assembly manual... and it shows the valve in both the vacuum schematic and the page described above.
Old May 29, 2018 | 10:55 PM
ezobens's Avatar
ezobens
It seems GM went back and forth on the hot water control valve over the C3 model run.
I found out the hard way when retro fitting factory A/C in my 69.
Since I accumulated parts from various years (69 thru 73-ish), I just assumed by looking at the 69 set-up that all years used the valves but not so...
Old May 30, 2018 | 11:09 AM
69_Shark's Avatar
69_Shark
FWIW I have the vintage air set in my 69 which included the water shutoff. I have recently added a water bypass so when the water is off, it can route back to the water pump.
The bypass is for of my in progress LS swap.
Oh yeah, NOT Stock.
Scott
Old Jun 1, 2018 | 10:38 AM
Kie's Avatar
Kie
My 1975 (1/75) L48 ac coupe for certain came with a shutoff valve from the factory.
To hot water valve
