Help - removable rear window sealing
Old May 29, 2018 | 04:23 PM
Sunset Orng 05's Avatar
Sunset Orng 05
Veteran: Marine Corps
Default Help - removable rear window sealing
I've done a search of this forum and I've researched the AIM but can't figure out what to use to attach the weatherstrip for the removable rear window. My search resulted in finding a lot of information about what people are using on the non-removable rear window but nothing explicit for the removable one. The AIM calls out 51f adhesive which crosses to an adhesive that is used in numerous places to include securing the carpet but I wouldn't think that the same adhesive is used to prevent water intrusion through the rear window as securing the carpet. As usual, thanks for any and all input.
Old May 29, 2018 | 04:30 PM
bazza77's Avatar
bazza77
I used this for all the weather-strips , including that rear removable one ,
https://www.ebay.com.au/itm/3M-WEATH...-/251556053150
Old May 29, 2018 | 06:48 PM
DUB's Avatar
DUB
Yes it would.
All it is...much like the adhesive in the last post....is a contact adhesive.
And knowing that a contact adhesive is applied on BOTH surfaces...then it would seal out water..
I use it and have NO water leaks IF it is applied correctly.
DUB
Old May 29, 2018 | 06:50 PM
68/BB's Avatar
68/BB
3M Black Super Weatherstrip Adhesive
Old May 29, 2018 | 08:03 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
that's what I used
Old May 30, 2018 | 09:44 AM
DUB's Avatar
DUB
Just be caerful due toeh time of year oyuare doiong this.
The glue can tack up so fast on you...depending on how thick you apply it that when you go all the way around BOTH the cars pinchweld area and also the contact surface of the w/strip itself...that when you go to put them together they have already skinned over too much and do not stick well.
Perform a test first and find out what you need to do...or you nay be doing it in sections.
I know I would not do it outside where the sun is heating the parts up.
I also use another product AFTER I have it installed due to I have it in my shop already but knowing if you want to go into that added expense. I use it when I go in and inspect how well I got the seal installed when I carefully pull back on the edge where the seal meets the pinchweld and see if I have any area for this pump grade product to be pumped into. CRL 1716 is what I use.
DUB
Old May 30, 2018 | 01:00 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The first thing you should do is clean the weatherstrip before you ever put glue on it. Then once you remove all the mold release from the rubber apply a thin bead on it with your finger and allow it to dry. Do the same with the window frame... spread and allow to dry. Once dry then apply a thin coat to the rubber again and install it as you go. I can assure you it'll never come loose. (I use weldwood glue here, but the 3m08008 will work just fine).
Also note, there were anywhere from four to six screws that secured the rear weatherstrip to the car. It seems to vary year to year.
https://willcoxcorvette.com/corvette...ow-coupe-68-74
Old May 31, 2018 | 09:07 AM
Sunset Orng 05
I know what you mean about the weather and it tacking up quickly; that's the reason I was looking at the forum and the AIM for the correct adhesive. It ended up getting so messy and wouldn't hold that I ended up removing it and had to clean it all up again. I'm sure that my next attempt will be to do it in sections as you suggested.
No worries there, I'm able to do it in the garage
I may give this a try as well. Is it readily available or something I would have to order online?
DUB
Thanks for help on this one.
Old May 31, 2018 | 09:15 AM
qball's Avatar
qball
What do you use to remove the mold release on the rubber? And what’s best to use getting the old glue off the frame?
Old May 31, 2018 | 09:34 AM
DUB's Avatar
DUB
Depending on the type of rubber. Which this rubber is solid and non porous. I use acetone or even some of my wax and grease remover I use when I am prepping for my paint jobs.
To remove the glue I use the 3M 08984.
DUB
Old May 31, 2018 | 09:44 AM
scrappy76's Avatar
scrappy76
This is what I used.
Old May 31, 2018 | 03:16 PM
0Willcox Corvette
Former Vendor
I like using the weldwood glue, it's so close to the original color and texture you'd be hard pressed to find anything else closer... the issue is we buy this in the gallon... you guys will have just as good of luck with the 08008 black 3m. (and mistakes hide easy). The industrial weldwood is what we use on all our tops as well... so when you glue it... it stays forever.
Willcox
To Help - removable rear window sealing
