major brake issue
Old Jun 12, 2018 | 03:14 PM
sha2333's Avatar
sha2333
Cruising
Default major brake issue
Proud 1st time Vette owner of a 74. having brake issues and needing some insight. Replaced the brake pads in April 2017 and all worked fine about August 2017 started having air in the lines, kept bleeding them, replaced the MC at that point and no change. Stored it for the winter in Utah, got it back out and addressed the issues by bleeding it again, 2 days later air in the system ended up noticing that front drivers caliper had been leaking badly as had another so I replaced all 4 and new pads and bled, 2 days later air again. Replaced MC again 2 days later air again. Short story I have replaced all 4 calipers/pads, MC (3x), rear flex lines, booster and I am still getting air to the front left caliper each time. Replaced that caliper again and 3 days later air in the system again. Just not sure what is allowing air to get in the system?
Any one else w/any similiar issues that can help out. Even my 3rd local brake shop seems to be at a loss (has it now looking some more).
Old Jun 12, 2018 | 03:37 PM
bashcraft's Avatar
bashcraft
Check the run out on that rotor. Is it still riveted to the hub?
Old Jun 12, 2018 | 03:54 PM
ignatz's Avatar
ignatz
Since you're new to this, you may need to know a little more. The brake system in these cars is unique or relatively so in that the brake pads rest on the spinning rotor. If the rotor wobbles, the pistons in turn move in and out in their cylinder bore pumping air into that caliper. So as bashcraft has mentioned, rotor runout may be what you are experiencing. Best checked with a dial indicator.
Old Jun 12, 2018 | 04:06 PM
sha2333's Avatar
sha2333
Cruising
Thanks.
Sorry I actually failed to state that I also replaced all 4 rotors as well.
sha2333's Avatar
sha2333
Cruising
Thanks.
Old Jun 12, 2018 | 04:09 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by sha2333
...failed to state that I also replaced all 4 rotors...
Run out should be checked on all four new rotors.
Old Jun 12, 2018 | 04:28 PM
Peterbuilt's Avatar
Peterbuilt
Default How to check and correct rotor run out.
https://www.youtube.com/watch?v=SSxC...ature=youtu.be
To major brake issue
