Any tips?
Old Jun 13, 2018 | 01:22 AM
Vettedreamer74's Avatar
Vettedreamer74
Default Any tips?
I'll be replacing the brake lines and hoses. I have never done this before, so was wondering if there is anything I should know or any tips to make the job easier. Thanks as always!
Old Jun 13, 2018 | 01:34 AM
Richard454's Avatar
Richard454
Three things-
(1) line wrenches
(2) PB Blast
(3) patience
Old Jun 13, 2018 | 01:36 AM
Vettedreamer74
Any way patience doesn't need to be involved
Old Jun 13, 2018 | 01:39 AM
NONN37's Avatar
NONN37
Are you replacing all of them? some are near impossible without lifting the body. Use really nice flare nut wrenches. I ended up using vise grips on a couple they were so tight. maybe soak them with penetrating oil.
make all the conncetions before installing the mounting tabs. youll need to finnese the tubes into place a little bit.
Old Jun 13, 2018 | 01:52 AM
Vettedreamer74
Well, I was replacing the brake proportioning valve on the 74, but couldn't get the fitting off of the line that heads to the rear brakes. Figured it wasn't a bad time to replace the lines. You've got me worried about lifting the body though. Because that won't really be an option at this point.
Old Jun 13, 2018 | 02:07 AM
NONN37's Avatar
NONN37
actaully on second thought just saw a diagram. I think its the gas lines that are mounted above the frame.
the brake ones are tight to the floorpans. I think theyre easeir to get to. theres a few tight spots on the exhaust reinforcement and at the rear block.
Old Jun 13, 2018 | 02:13 AM
Vettedreamer74
Ok, sounds good. Scared me for a minute!
Old Jun 13, 2018 | 03:19 AM
The13Bats's Avatar
The13Bats
If they are original while fitting wrenches are wonderful pretty much plan to go right to vice grips
Old Jun 13, 2018 | 06:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: brake lines can last the life of the car. Are you certain you need to replace them?
Old Jun 13, 2018 | 08:46 AM
Vettedreamer74
Good to know, thank you!
the fitting on the line to the rear brakes wouldn't come off the proportioning valve, so instead of just doing one line, figured I might as well get them all done for piece of mind. Plus I had a really soft brake pedal. Air is getting introduced somewhere.
To Any tips?
