Rust Removal
Old Jun 13, 2018 | 01:10 PM
slapjack9's Avatar
slapjack9
Default Rust Removal
I'm in the process of making my steering box pretty again. But my (spline?) gear that connects to the rag joint/steering column is super rusty! Does anyone have any tricks to dissolve it? It would be tough to soak the whole thing in a rust remover from the store.
Old Jun 13, 2018 | 01:27 PM
Bikespace's Avatar
Bikespace
I used a wire brush at the end of a drill. Post #23 shows the after (but before I collapsed the column for the Borgeson install)
https://www.corvetteforum.com/forums...-thread-2.html
Old Jun 13, 2018 | 01:41 PM
Gold Dragon's Avatar
Gold Dragon
Coat the box with Evaporust, available at any auto parts. After you soak it, wrap it with plastic wrap and leave overnight. should dissolve the rust on the splines.
Ray
Old Jun 14, 2018 | 09:39 PM
naramlee's Avatar
naramlee
vinegar... submerge it for 2 days and it will be 100% new when u remove it
and it's cheap and available at any super market
Old Jun 16, 2018 | 01:31 PM
tubman's Avatar
tubman
Just remember, vinegar is an acid (albeit a weak one) which can attack the base metal. "Evaoporust" works by "chellation" which will only remove the rust and leave the base metal untouched.
Old Jun 16, 2018 | 02:20 PM
derekderek's Avatar
derekderek
does the hub and spline go together and come apart well? then leave the spline alone. everything you clean off the spline teeth makes them smaller and looser in the coupler. cleanup the parts that show.
Old Jun 16, 2018 | 05:11 PM
naramlee's Avatar
naramlee
correct, after two days I mic'd some axle parts and didn't show anything past 10 thousands with a Starrett micrometer so it's not enough to worry about on most things, you do need to rinse it, and oil/paint immediately though, you can actually watch the bare metal turn light orange in about 20 mins with our Arkansas humidity.
Old Jun 21, 2018 | 09:25 AM
slapjack9's Avatar
slapjack9
Thank you everyone! I ended up going with the wire wheel method since I had one laying around. I'll post some pictures tonight!
To Rust Removal
