I think most 77 owners will agree that the environmental controls for this particular year stink. Specifically the selector switch. Its all vacuum actuated and just poorly conceived. So, has anyone come up with an alternate, custom or "trick" way to improve this functionality?
After an LS swap I decided on no A/C and just wanted to simplify the system to Heat only so I'd still have a defrost function. I purchased an A/C delete heater box from a forum member and I tested it before install. It worked fine, but even a new selector switch won't direct the air properly. I don't think its even activating the valve out under the hood to cut off the hot coolant supply to the core, because I'm getting way too much heat inside the cab. For these summer months I've got to find a way to improve this system.
Ideas?
Ideas?
I have an AC '77, and I'm struggling to get the system to operate as designed. I wish there was a way to dump the vacuum without forking over huge pile of money. I looked into the Vintage Air setup - it replaces the vacuum system with electrically operated air doors but it's too expensive for my taste. It also doesn't bolt in to a 77 because we're a weird one-off year. Maybe you could piece together a non AC system that would be affordable.
My approach for now is to see if i can resolve the leaks by refurbishing the control switch. I'm polishing the mating surface that directs the vacuum so as to get a better seal. I initially bought a new switch, but that one leaked right out of the box too. All my hoses are good and the actuators do what they ought to when tested individually, so the problem has to be at the control end.
I'd also be interested in finding out if anyone else out there has a better way. The vacuum system sucks. Haha.
Rookie suggestion about the "heat box" under the dash: Decide if you want vacuum or electric controls/install TWO new identical On-Off valves (both vacuum or both electric) in the firewall heater hoses--one in the supply & one in the return (it's a debatable whether the extra valve is needed, but I think it does a better job of keeping hot water out of the heater core).
As for the vacuum control switch, you probably know the smoothing process is called "lapping", which requires a piece of surface-ground marble about 6" x 6" or larger/apply lapping compound to the surface and move the control piece in a "figure 8" pattern until the surface has an even appearance/no low areas....then use a finer lapping compound. Once both control pieces are lapped smooth and wiped clean, apply a very thin coat of silicon grease and smooth it over the lapped surfaces (I do not know if there is a small spring or thin wavy washer that holds the two haves together but there should be in order to keep a constant seal between the lapped halves.)
I hoped that helped solve a couple problems
I have actually considered replacing the vacuum actuated valve with a manual valve. Then, in the summer months just manually cut off hot coolant circulation to the core. Just not sure I'd like the look under the hood.
FWIW: I did that, but down South as you know it can be 28*F one day and 88*F two days later.....I was under the hood every week during "the Winter" opening or closing manual valves for a day or three at a time. Then there are those summer mornings when the windshield is fogged.
I thought it wouldn't be a hassle, but it got old fast
