Electric window problem
Old Jun 15, 2018 | 07:11 PM
Joker66's Avatar
Joker66
Cruising
Default Electric window problem
Hello could anyone direct me to a post that covers power windows problems . Thanks
Old Jun 15, 2018 | 07:19 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and Welcome!
What year is your Corvette?
A description of the problem will help with the diagnosis.
Old Jun 15, 2018 | 07:27 PM
Joker66's Avatar
Joker66
Cruising
1979 . The problem I'm having is the drivers window switch only works one way. To Get the window up and down the wires at the motor have to be reversed. I thought it was the switch. But I hooked the passenger switch. To the drivers plug and it does the same thing. And both switch's will opperate the passenger window just fine . I'm lost
Old Jun 15, 2018 | 07:32 PM
sparky77's Avatar
sparky77
Sounds like you have a broken wire going from the switch to the motor.
Old Jun 15, 2018 | 07:40 PM
Peterbuilt's Avatar
Peterbuilt
I agree.
The wires can break inside the rubber conduit from the body to the door.
Test for continuity from the switch to the motor connection.
Old Jun 15, 2018 | 07:47 PM
Joker66's Avatar
Joker66
Cruising
Would you have any idea if two wires (not the power wire) are continuous or do they run thru other stuff
Old Jun 15, 2018 | 08:04 PM
Peterbuilt's Avatar
Peterbuilt
Default One continuous wire.
Take the sill plate off and the lower left kick panel and with the PW motor wires disconnected pull the wire forward and solder the break.
Old Jun 15, 2018 | 08:18 PM
Joker66's Avatar
Joker66
Cruising
Thanks you guys are great. Looks like I know how my Saturday morning is going to start
Old Jun 16, 2018 | 10:14 AM
sparky77's Avatar
sparky77
Yes they are continuous from switch to motor
Old Jun 16, 2018 | 10:28 AM
naramlee's Avatar
naramlee
I had a terminal corrode at the motor itself FYI, it was fine once I pulled it and cleaned it
Old Jun 17, 2018 | 01:15 PM
Joker66's Avatar
Joker66
Cruising
Thank you all for the advice. I found the break in the line just inside the kick panel. Thanks again.
To Electric window problem
