77 clock
Old Jun 18, 2018 | 02:27 PM
jackienbrian@msn.com's Avatar
5th Gear
Default 77 clock
Afternoon all, I have a 77 vette and the clock has always been about 2 hours ahead. I can't for the life of me figure out how to set it. Any advice? Thanks
Old Jun 18, 2018 | 02:38 PM
7T1vette's Avatar
7T1vette
The 'complicated' method would be to remove one of the cables from your battery, and then reinstall it exactly two hours later.
The appropriate method would be to pull outward on the time-setting ****, and while in that outward position, turn the **** until the time is correct. (It is best to turn the **** in the direction which takes the least number of rotations to set the correct time.)
Old Jun 18, 2018 | 02:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Pull the chrome **** stem out, then turn it.
Old Jun 18, 2018 | 03:44 PM
5th Gear
Thanks,
That's what I figured, my **** was not working. It's the little stuff that drives ya nuts. Thanks again all.
Old Jun 18, 2018 | 10:35 PM
7T1vette's Avatar
7T1vette
If the clock runs, you could still use the 'intermittent' battery approach.
Old Jun 19, 2018 | 07:33 AM
Bikespace's Avatar
Bikespace
Or move two time zones east. My **** broke off inside, too. It is probably fixable, but a lot of the interior needs to come out to access the clock.
Old Jun 19, 2018 | 07:42 AM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
Originally Posted by jackienbrian@msn.com
Thanks,
There is a small gear pressed onto the end of the clock adjuster shaft that may possibly have slipped off...or...some obstruction in the clock is keeping you from being able to pull the **** out far enough to engage the gear with the clock mechanism. To fix it you will have to remove the clock and open it up on the bench.
Old Jun 19, 2018 | 09:09 PM
7T1vette's Avatar
7T1vette
If you go to that much trouble, just put a quartz mechanism clock in its place. I've never seen an original Borg clock that ran and kept good time for more than 5 years (actual running time...not 5 years but only running an hour or two a day). Install quartz and never dive in there [for the clock] again.
To 77 clock
