Talked to spec clutches. They seem to think 26 was heavy duty. I thought m22 had 10 spline as,well as straight cut gears.Makes me wonder if they know much about them.Said I needed same clutch as big block
Good grief. Then a standard 26 spline disc 11 inch clutch should work providing the sell me right throw out bearing. Already pulled two ram muscle car clutches due to defect
All 1971 Muncie 4-speeds (M20, M21, M22) had 26 input splines - so tells you nothing.
Number of grooves on the input shaft though may tell you what you have if it's unmolested.
M20 = 2, M21 = 1, M22 = none
1970 and up Muncie uses 26 spline input shaft on everything (M20, M21, M22) including base models. The tailshaft housing has only 3 shifter mounting holes so they are easy to identify.
In 1970 only 454 Chevelles got M-22's with 26 spline input/32 spline output...
All other M-20, M-21, and M-22's used 10 spline input/27 spline output...
In 1971 and later all Muncie's used 26 spline input/32 spline output...
