Body Lifting Question
I have a 1977. Engine, front suspension, dash, and interior is out. I want to lift the body high enough to replace the body mounts (I have found many procedures for this.). Can the body be lifted high enough (6-8 inches all the way around) to first allow for easier brake line, fuel line, and frame painting work? It's not practical for me raise and relocate the body. It's a driveway restoration so everything needs to stay in place under one tarp.
Has this been discussed and documented on this site. I am going through search results now. But, as you know, this type of search returns LOTS of threads to sift through.
Thanks in advance,
divots
If your bird cage is in good shape, you can get away with it. Mine was in decent shape, so I only lifted enough to restore the frame and suspension. About four feet up. If you're interested I have pictures on my members page. You will need some sort of gantry to lift from if you're doing this outside. Good luck man.
Below is a general outline of how I raised my 1968 body 6" to 8":
Once you have all the mounting bolts, E-brake, bumper mounts, rag joint, ground cables, electrical harness that could be too short to leave connected, etc. unbolted, you can lift the body in 2" increments to keep from flexing the fiberglass panels too much. Once you have lifted the body about 8" use solid wooden 4" by 4" by 8" long blocks between the frame and the bottom of the birdcage (do not use stacks of short wooden blocks as they can shift and cause the body to FALL). Also be sure to support the front end and rear end of the body as you raise it and keep both ends supported the entire time it is lifted (you can fabricate simple 2" by 4" uprights to support the underside of the front/nose and the rear area.
Click on the link below for pics of lifting my car body………………
https://www.corvetteforum.com/forums...post1591645717
Thanks for the replies and updates. I have been able to remove the No 2, 3, and 4 body mount bolts from both sides normally! Cages and nuts are still intact and functional. I feel really lucky. I'll tackle the No 1's this week; then on to freeing the body and raising it up around 8 - 10 inches.
divots
https://www.corvetteforum.com/forums...placement.html
Thanks in advance,
divots
