C3 Brakes
Old Jul 11, 2018 | 06:18 PM
JAMES69's Avatar
JAMES69
Default C3 Brakes
Folks,
The left front caliper on my 1969 vette (350/350) started dripping fluid. Thought it would be an easy job and ordered a new caliper, new pads and new brake hose. Well, I could not get the old brake hose off the old "small" brake line (they attach just inside the wheel are). Where they attach was pretty corroded, so I opted to order a new brake line (the small one that goes from the brake hose to the brass proportioning block). Now the big problem. I cannot get the old brake line out of the brass proportioning block. I tried several 9/16 wrenches (and muscle), didn't work. Tried penetrating oil (and time), didn't work. I cut off the old brake line at the "nut" going into the block, put on a socket (and muscle), didn't work. I took a torch t heat up the nut (several times), didn't work. Removed the alternator to give me more room (and muscle), still didn't work.
Any advice?
Jim
Old Jul 11, 2018 | 07:33 PM
caskiguy's Avatar
caskiguy
Originally Posted by JAMES69
Folks,
Any advice?
Jim
Buy a new proportioning valve ? Tough location for sure. Spray the other connections ( wait a few days ) and see if you can remove the lines. Sorry you're in a tough spot.
Good Luck.
Old Jul 11, 2018 | 07:56 PM
gguillot's Avatar
gguillot
Folks,
Any advice?
Jim
If you haven't rounded the nut off by now, count your blessings. How about the other connections on the proportioning valve - can you break them loose? If you can, you might be able to remove it from the car and place it in a vice to remove the stubborn fitting.
Old Jul 11, 2018 | 09:02 PM
JAMES69's Avatar
JAMES69
Unfortunately, the nut doesn't have a lot of "flat" edges left (my Irish temper didn't help). I tried the other lines going into the proportioning valve, none will move even with the penetrating oil!!
Old Jul 11, 2018 | 09:23 PM
Cooter Tech's Avatar
Cooter Tech
Folks,
Any advice?
Jim
How much heat, propane torch or oxy acetelyne? Heat, lots of it, cherry red fitting(s) to break them loose. I would think that a new proportioning valve and a total brake fluid flush will be required. Remainder of your options aren’t pretty if you can’t get that fitting off. Too late for the stubborn fitting, but good quality flare nut wrenches also help with stubborn fittings.
Old Jul 11, 2018 | 09:26 PM
MajD's Avatar
MajD
I have had some success with grinding flat spots on either side of the nut and clamping it with vise grips. I don't know whether you can fit a vise grip in there or not. If you have to take the proportioning valve off the car, you could definitely try that using a bench vise to hold the valve. Good luck.
MajD.
Old Jul 12, 2018 | 01:12 PM
JayRay's Avatar
JayRay
After I rounded mine off and they were still stuck I used a small pipe wrench and it worked. The pipe wrench liked the grip on a rounded nut.
Old Jul 13, 2018 | 08:29 PM
JAMES69's Avatar
JAMES69
The pipe wrench worked!!!!!! Thank-you so much, saved so much work if I had to remove all the lines etc!!
Jim
Old Jul 13, 2018 | 09:49 PM
JayRay's Avatar
JayRay
Glad it worked out, do a burn out for me and throw some Corvette Karma this way, on my way to the garage
Old Jul 13, 2018 | 10:47 PM
gguillot's Avatar
gguillot
Jim
Glad to hear! Been in similar predicaments while working on my old Vettes. Never fun when it happens, but always great when you get through it! All part of the experience of working on these great old cars.
To C3 Brakes
