Original Engine Components
Old Jul 26, 2018 | 08:42 PM
naramlee's Avatar
naramlee
Aviation or AFF gas is the best around here and it's half the price of racing fuel, best way to run more compression
Old Jul 27, 2018 | 07:53 AM
slapjack9's Avatar
slapjack9
Thank you everyone for your input! A few things, this car would not be getting judged,and I'm not concerned with "numbers matching." I can see pros and cons from both sides here. I don't own anything modern performance, so here's my big question, the performance SBC and BBC engines back in the day all had such unique sounds, would a modern 427 sound the same (assuming it's cammed the same way etc etc) as one that was built back then? I'm sorry if this sounds ignorant or is a stupid question...but you guys are the experts!
Old Jul 27, 2018 | 09:38 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
With a roller cam the lope would be different due to the ramps and LSA.
Old Jul 27, 2018 | 10:42 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
Keep the block, throw away everything else, build motor with modern components crank, rods, pistons, heads.
how much hp.? depends how much you spend on components.
minimum investment in parts for quality components around 5k depending on hp.
Old Jul 27, 2018 | 03:27 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Auto engineers spend a lot of time perfecting exhaust sound these days. Are they driven by old school exhaust sounds? Of course they are! So build old school and have the sound everybody wants these days out of a modern performance car.
Old Jul 27, 2018 | 06:27 PM
TimAT's Avatar
TimAT
I'll add that finding pistons for a 427 is difficult too- for some reason all the piston guys have 83 varieties for a 454 and -0- for a 427.. They'll custom make them, but bring your checkbook.
$2k will get you a balanced 496 rotating assembly- crank rods,pistons, bearings and rings. And from the outside, nobody can tell.
Old Jul 27, 2018 | 07:24 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
That unique sound you are referring to is very high compression. The engine is pounding at idle, just trying to stay running. NO modern cars are running 12 or 13 to 1 compression that I am aware of. The advent of fuel injection, turbocharging, supercharging, or any combination of all three, have eliminated the need. No expert, just an old timer.
Old Jul 28, 2018 | 07:49 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
No but 11:1 is not uncommon these days on newer cars. Very high compression is not needed for a nice lopey sound.
Old Jul 28, 2018 | 08:48 AM
cv67's Avatar
cv67
St. Jude Donor '05
Firm believer that compression motors work; get the cam profile right it will sound "right" especially at higher rpm
Add a solid lifter cam its pure music....gets that diesel like sound in the interior. not enough compression and a lumpy cam just sounds..lazy
Talk to a local builder you trust, sit down and plan. I wouldnt go out of your way to sink money into 50+ yr old parts.
Old Jul 28, 2018 | 09:11 AM
Dynra Rockets's Avatar
Dynra Rockets
Mazda has been running 13:1 static with their SkyActive engines for a few years now. Accomplished through direct injection, piston shape and cam profile. I read the next generation due out next year is going 16:1 CR. In their application the high CR doesn't produce any more power than a contemporary 10:1 CR engine, but it does improve fuel economy substantially.
Old Jul 28, 2018 | 02:31 PM
vettebuyer6369's Avatar
vettebuyer6369
Hey everybody,
As some of you know, I'm in the middle of a 75 restore, so this isn't anything that will be happening soon, but I am curious.
My dream car is a 69 black/red L88. Unfortunately, they're few and far between and will be even more so when I have the means to get one.
So I've been thinking, there are plenty of original 427 69s...if I had one of those, could I put the components used in the L88 into say an L36, L68, or L71 block and essentially "clone" the L88 engine?
If so, where can I find the data on the components they used? And is there somewhere I can buy them individually?
Any suggestions or help would be greatly appreciated!
Riley
There was a guy selling your dream car, right down to the colors, at Mecum in Indianapolis in May:
Old Jul 28, 2018 | 02:37 PM
vettebuyer6369
Only $79k.
https://www.mecum.com/lots/SC0518-32...e-convertible/
Old Jul 28, 2018 | 03:01 PM
  #33
dmaxx3500's Avatar
dmaxx3500
Hey everybody,
Riley
why don't you just buy my ''1969 427/400hp tri-power conv,all restored and just needs paint
