Original Engine Components
Old Jul 26, 2018 | 11:12 AM
slapjack9's Avatar
slapjack9
Default Original Engine Components
Hey everybody,
As some of you know, I'm in the middle of a 75 restore, so this isn't anything that will be happening soon, but I am curious.
My dream car is a 69 black/red L88. Unfortunately, they're few and far between and will be even more so when I have the means to get one.
So I've been thinking, there are plenty of original 427 69s...if I had one of those, could I put the components used in the L88 into say an L36, L68, or L71 block and essentially "clone" the L88 engine?
If so, where can I find the data on the components they used? And is there somewhere I can buy them individually?
Any suggestions or help would be greatly appreciated!
Riley
Old Jul 26, 2018 | 11:43 AM
bashcraft's Avatar
bashcraft
You would be better off using this https://www.chevrolet.com/performanc...g-block-zz-427
Old Jul 26, 2018 | 11:49 AM
slapjack9's Avatar
slapjack9
Originally Posted by bashcraft
For any reason outside of ease?
I'd rather not put a modern engine in the car if I can avoid it.
Old Jul 26, 2018 | 11:57 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by slapjack9
...could I put the components used in the L88 into say an L36, L68, or L71 block and essentially "clone" the L88 engine?...
https://www.corvetteactioncenter.com...l88engine.html
Short answer is Yes. You can gather the parts and build an L88. Expect it to be expensive. You will need a source for 108 octane fuel.
Old Jul 26, 2018 | 12:00 PM
slapjack9's Avatar
slapjack9
Awesome! Are these just readily available parts? Or is there a specific place that stocks this stuff?
In terms of octane, additive will get it there correct?
Old Jul 26, 2018 | 12:20 PM
Dynra Rockets's Avatar
Dynra Rockets
NCRS-type parts will be hard to come by and be very expensive. What I mean by that is exact part# and date coded carb and heads as examples. If all you want is to mimic the look and power level of a L88 then aftermarket 12:1 pistons, off the shelf holley carb, off the shelf cam, aftermarket aluminum heads and repo air cleaner are all easy to find.
Old Jul 26, 2018 | 12:25 PM
slapjack9's Avatar
slapjack9
Just trying to mimic the look, sound, and power of that engine. For the cam though, did they publish the duration and lift of it so I can get one that's identical? If that info is in the link above I haven't had a chance to comb through it yet.
bashcraft's Avatar
bashcraft
A real L88 has 12:1 compression and is not streetable unless you're running $10 a gallon race fuel. The ZZ427 has 10:1 compression that will run on 93 octane.
Old Jul 26, 2018 | 12:27 PM
slapjack9's Avatar
slapjack9
I'm aware of the compression ratio and high fuel cost issue. I wouldn't be driving this car more than once a week if that.
Old Jul 26, 2018 | 01:05 PM
Easy Mike's Avatar
Easy Mike
...Are these just readily available parts?...
No. They've been out of production for years.
...is there a specific place that stocks this stuff?...
No. You'll have to search until you find them.
...In terms of octane, additive will get it there correct?...
Probably not. You'll need aviation fuel or something NASCAR equivalent.
Try Google. Quite a lot has been about the L88 over the years. You should be able to put together a parts list.
Good luck.
Old Jul 26, 2018 | 02:50 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
The same 3963512 block was used for L36 thru L88 and finding one is not a problem. I would NOT suggest buying a 69 with it's original drivetrain and start modifying it. You would be better off getting a lesser car and putting together all the parts necessary to make it a "clone" or "tribute" L88. I know where there are several complete L88 and ZL1 engines, as well as M22s. You can also find the parts for F41 suspension, J56 brakes and shroudless radiator for those 160 mph straightaway. When you are done, you will have a car that is hard to start, overheats in traffic and will break parts at will. VP has a 108 octane C12 race fuel that will set you back $12 a gallon...unless you can get 55 gallon drums delivered to your house.
If you decide later to sell it, you might be lucky to get back 25 cents on each dollar spent putting it together...providing you do all the work yourself.
Old Jul 26, 2018 | 03:15 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
This is what I'd do and throw on an L-88 intake air assembly. 99% of people looking at it wouldn't know a real L-88 from a clone.
Old Jul 26, 2018 | 03:22 PM
Iceaxe's Avatar
Iceaxe
Is what everyone is trying to tell you in a nice manner is if you are just trying to mimic the look, sound, and power of the L88 you are going about it all wrong... With a little ingenuity and modern parts you can accomplish your desire with less money, less headaches and have something drivable when your finished.... your mileage may vary....
Old Jul 26, 2018 | 03:23 PM
derekderek's Avatar
derekderek
Are you building this car to race it? If not, cam and CR need to be rethought. A hyd roller is a way better way to go. If you have any 427-454 with any-even peanut-factory mk-4 heads with the L88 intake, nobody but you and show judges are gonna know it is not an L88. And no matter how orig it is, right down to the right stamping on the distributor bolt, the judges are STILL gonna know it is not an orig L88.
Old Jul 26, 2018 | 03:44 PM
TimAT's Avatar
TimAT
With the advances made in technology since the days of the L88/ZL1, you can stumble around in a dark room with sunglasses on and make more horsepower/torque than those 2 engines did when they were new. IF you're determined to run 103-110 octane fuel, ($8.50/gallon where I live), even going to the local cruise night is going to be expensive. You can build a pump gas happy BB, drive it like a rental car, and still not break the bank. On 91-93 octane fuel. Been there- MY 69 had a crate L88 and after that died, (amazing what the inside of a BB looks like after the cam breaks!), a crate LS7. Now it's a 496 with 10.5 compression and is happy as a clam on 91 octane fuel. And way more HP/TQ.
Old Jul 26, 2018 | 03:54 PM
Kevova's Avatar
Kevova
There was a time when every 427 was a L88 and Muncie was a "rock crusher"
If you're just going for the look bbc crate engine with aluminum heads and intake. Do you really want to spend you days adjusting valves and the carb so you can drive it. Honestly, I am over that. I just want to get in it and go.
Old Jul 26, 2018 | 05:41 PM
derekderek's Avatar
derekderek
Scare up a mercruiser 365 Mag. It is except for the cam, a 71 LS6. Right down to the Winters snowflake on the intake-at least on the earlier ones. Forged crank, 7/16 dimple rods, forged small dome pistons, 2.19 rectangle heads.
To Original Engine Components
Old Jul 26, 2018 | 08:04 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
You can find a 427 block at a machine shop or on craigslist/ ebay. The crank, aluminum heads and appropriate pistons and cam all can be found at Jegs or Summit. You dont need the original parts, just the specs and it will look and sound like the original. You can get the ecklers hood with the cold air intake from a corvette vendor and buy the low profile air cleaner from paragon. It'll still cost a good $5000 -$7000 (another $2000 for a new block)
to put it together yourself with good parts but its cheaper than the original
Old Jul 26, 2018 | 08:31 PM
cv67's Avatar
cv67
St. Jude Donor '05
Or call up someone like Mark at Vortecpro, order up a 468 or bigger, stick a solid lifter cam in it, put your 427 air cleaner on it;as said most wont know the difference
Use a modern grind and head, youll make more power and be somewhat driveable for WAY less money. Plenty of 454 blocks out there even a studded 2 bolt main can take a beating with decent machine work.
Old Jul 26, 2018 | 08:32 PM
694speed350's Avatar
694speed350
no it won't
