Wiper Door Vacuum
Old Aug 5, 2018 | 10:01 AM
jdru66's Avatar
jdru66
Default Wiper Door Vacuum
Hi I printed out a few vacuum posts and will research more on the forum so I apologize if this is a duplicate. I am just trying to solve my problem quickly.
My 72 wiper door only opens when you pull the override lever. All other vacuum works lights are fine etc. The door opens fine with the over ride and the wipers work fine. I tried replacing the switch behind the tach and that did not resolve the issue.
Any help or advice on what to check next would be appreciated.
Old Aug 6, 2018 | 05:47 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Did you look at Willcox's site for the trouble shooting guide?
Old Aug 6, 2018 | 06:42 AM
jdru66's Avatar
jdru66
I ordered that guide and it should be here this week. I am thinking either the switch on the tach isn’t getting juice or maybe I got a leak from the switch to the override? We shall see.
Old Aug 6, 2018 | 07:21 AM
bfit's Avatar
bfit
Am I seeing this correctly .
you turn on wipers , nothing until,you pull the override down
Old Aug 6, 2018 | 07:35 AM
jdru66's Avatar
jdru66
That is correct. I turn the wipers on and nothing happens until I pull the override.
Old Aug 7, 2018 | 12:13 AM
bfit's Avatar
bfit
OK that is strange, something is connected incorrectly , but that is obvious .
I have the dash out if my 70 model, I'll refresh my mind on where the pilots lines run. Ill be back to you,
one other thing,when you turn the wipers on does the door lift up, or does that happen when you pull the over ride down,
Bfit
Old Aug 7, 2018 | 07:32 AM
jdru66's Avatar
jdru66
Thank you. I will be pulling my dash as soon as I make room in the garage for the car to sit apart for a few days. I also need to replace a speaker and the ac duct that goes under the steering wheel was missing when I bought the car.
I am am wondering if my issue could be as simple as the actuator on the back of the tach not getting power when the wiper switch is pushed. I did not think to test that when I had it apart last time.
Old Aug 7, 2018 | 12:06 PM
7T1vette's Avatar
7T1vette
Did you connect the solenoid switch (behind tach) correctly? The port sticking out the end of the switch is a VENT and should not have anything connected to it. If you connected a vacuum hose to that [end] fitting, that's why it isn't working.
Old Aug 7, 2018 | 12:17 PM
jdru66's Avatar
jdru66
Thank you, yes it is hooked up correctly. I was initially confused on that so I triple checked before installing.
Old Aug 7, 2018 | 12:37 PM
7T1vette's Avatar
7T1vette
You can check that switch by connecting 12 vdc to the wiring and attempting to blow or suck through the vacuum hose connections. Turning the unit ON/OFF should allow air to pass or to not allow air to pass. For a function check with it in the car, turn ignition to ON (engine not started) and turn ON/OFF the wiper switch while trying to blow thru the vacuum line connected to it. If the test fails, the problem could be that no power is getting to the switch (check with voltmeter) via the wiper switch OR the new solenoid switch is defective (it happens!).
If that testing is successful and you still can't open the wiper door, you may not have vacuum getting to that solenoid switch OR the safety switch under the right side wiper is the problem (either with its positioning or being faulty). As mentioned above, check out the diagnostic info and vacuum circuit on Willcox site.
Old Aug 7, 2018 | 06:58 PM
bfit's Avatar
bfit
This is difficult to describe I’ll do a drawing
bfit
To Wiper Door Vacuum
