Need advice
Old Aug 7, 2018 | 09:06 PM
sixx27am's Avatar
sixx27am
Default Need advice
Hi all I’m looking at another C3 this one is a 76 L82 four speed with 22,000 original miles. The front and rear bumper covers have disintegrated and I have some concern about the amount of rust on the frame. The car appears to have the gymkanna? suspension as there are nine leafs on the rear spring, air conditioning, power windows, alarm system and I think rear defroster (there’s a little switch next to the drivers me that says on when you click it ) the interior is in good shape and just needs a cleaning. We are at $6900 right now. Could I get your thoughts on the rust and any other points? Thanks in advance
Old Aug 7, 2018 | 09:09 PM
sixx27am's Avatar
sixx27am
One thing I forgot to mention that I thought was weird. The car has a 2 into one exhaust, is that factory?
Old Aug 7, 2018 | 09:17 PM
2TONE82's Avatar
2TONE82
I'm a C3, 82 and C5 Z06 guy...by no means an expert but I can tell you it has been repainted (door trim tag you took a picture of would not have been painted over) and it has aftermarket wheels on it. Also, I'd double check the VIN and motor to ensure it is an L-82 car. Rust on suspension appears to be normal surface rust from my experience. However, something is up with that interior/dash...is that dirt in the finish? Enjoy the hunt!
Old Aug 7, 2018 | 09:40 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
A few things for you to consider:
The rust isn't out of control in the pics.
The car SHOULD be drivable for that price.....BUT I wouldn't try to start a car that has 15 year old oil in the engine and old gas in the tank/carb.
The old tires would make it unsafe to test-drive because they could literally explode.
Old Aug 7, 2018 | 09:41 PM
henrikse's Avatar
henrikse
More rust than I would expect. Looks like needs front and rear bumpers. Engine looks dirty. I would keep looking
Old Aug 7, 2018 | 10:49 PM
Bills17n72's Avatar
Bills17n72
I dont think that the odometer is correct ,has more miles than what is showed!
Old Aug 8, 2018 | 12:45 AM
Vet76te's Avatar
Vet76te
All C3 Corvettes from 1975 thru 1982 came from the factory with a faux dual exhaust system, (2 into 1, back into 2). This was for the catalyst converters. They were expensive, so doing one saved money.
Most of them ended up getting retro dual exhausts added when the exhaust needed repacked.
Old Aug 8, 2018 | 07:29 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Just a couple of points worth noting. The frame rust, in my opinion, isn't normal rust for a car with 22,000 miles unless it sat outside over dirt or grass for quite a length of time. I think I see rot in one of the pictures on the side rail of the frame, and that would be very problematic. I have restored eight or nine C-3 frames and I would want to do more investigation on this one before making a decision. Original color is white but someone painted over the tag meaning it is either a repair, repaint, or touch up job. I had the same thing on a 77 I bought but it was an orange car repainted with white. Two to one is normal on exhaust, should have it's catalytic converter still in place if never replaced then. I bought a 1977 with 78,000 miles on it, running and driving, for $4,000. I would that for $6,900 you can get a much nicer car in running condition. I wish I was close enough to inspect it for you, engine condition looks rough for 22,000 miles.
Remember these are just my observations from pictures of what we can see and it may be much nicer in person.
Good luck with your search.
David Howard
Old Aug 8, 2018 | 07:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I see age and a lot of work to do, but I don't see a deal breaker. The car is pretty much stock.
Old Aug 8, 2018 | 07:58 AM
sixx27am's Avatar
sixx27am
David Howard
Thanks David after sleeping on it, I agree, I'll keep looking!
Old Aug 8, 2018 | 08:25 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Good call. Best of success with your search and best regards,
David
Old Aug 8, 2018 | 10:33 AM
teamo's Avatar
teamo
The nine leaf spring is the standard suspension. Gymkanna suspension had 7 leaves, heavier spring rates in the front, and a rear sway bar. Looks like a lot of rust in the pictures, but I know from taking pictures of my own frame that the pictures made it appear worse than it really was. It is hard to say without seeing it in person. If you could inspect the car and get under there and poke around on the frame you'll be able to tell if it is just surface rust or rotted through.
To Need advice
