1969 Starting problems
Old Aug 9, 2018 | 09:05 AM
PepesVette's Avatar
PepesVette
3rd Gear
Default 1969 Starting problems
I have a 1969 427/400 tripower car. Starter was rebuilt, battery was load tested and found to be OK. Will not start. Acts like it is not getting enough juice to start. It tries to turn over but just seems too slow and laboring. Where do I start troubleshooting? I am told many problems start with bad grounds, but do not know where to start looking. Any help greatly appreciated. Thanks in advance for help, Joe B
Old Aug 9, 2018 | 10:16 AM
SB64's Avatar
SB64
I know battery was load tested but it's real easy to just try a known good battery . Just my 2 cents!
Old Aug 9, 2018 | 10:30 AM
hope2's Avatar
hope2
What has changed since it started ok? Like post 2 says, easy to swap battery.
Old Aug 9, 2018 | 02:34 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
replace original, internally corroded, main battery cable.
verify and replace ground cables too.
you can not look at cables and say ok looks good.
Old Aug 9, 2018 | 07:10 PM
Gold Dragon's Avatar
Gold Dragon
Double check your starter connections. If its a recent install, maybe a loose wire. Agree with grounding as a place to start. check where the main ground attaches to the frame and clean it well.
Old Aug 12, 2018 | 06:16 AM
PepesVette's Avatar
PepesVette
3rd Gear
Thanks to one and all for responses. I will check all connections starting with the battery. The battery cables have been replaced. I did check with two "good" batteries. This car has had problems since I bought her in 2001. Had to put a battery disconnect in to stop battery from going dead while sitting. Have kept trickle charger/maintainer on battery most of the time. Never had this happen before. I am going to restore car and replace all wiring harnesses. Just wanted to get her back on the road for one last blast once the weather cools down a bit before taking her off the road for what will likely be a couple of years. I will let you all know what I find soon as I get a look.
Old Aug 12, 2018 | 06:21 AM
PepesVette's Avatar
PepesVette
3rd Gear
Default Main Ground Wire
Where do I look for this main ground wire? Goes from block to frame I assume so somewhere in the front? Do I need to look from underneath? Thanks
Old Aug 12, 2018 | 06:48 AM
7T1vette's Avatar
7T1vette
The ground cable going from the right-front frame to the motor mount & starter front mounting bracket is IMPORTANT!. INADEQUATE CURRENT will get to the starter unless that ground wire is present and in good condition (not swiss cheese inside the insulation). The engine might start if that cable were not there; but it would have to get ground by some other pathway and you WOULD have starting problems.
Old Aug 12, 2018 | 07:12 AM
derekderek's Avatar
derekderek
The really important one is batt neg terminal to frame. Once cable leaves the batt box, it is only a couple 3 feet to back of trans. A second big ground run there, I think, would make sense.
Old Aug 12, 2018 | 07:16 AM
derekderek's Avatar
derekderek
69vette sez you can't look at a battery cable and say OK, looks good. You can look at a cable and say it looks good. You can't tell it will pass enough or any amps. But you can tell it looks good.
To 1969 Starting problems
