Tyre pressures
i pumped tyres up to 40 psi and noticed when cornering a little hard getting tyre squeal front wheels plus it feels a little light. Just wondering what the best tyre pressure would be for this size tyres. I’ve backed off a o 38psi but haven’t tried the twisty road yet
what you guys using with similar tyre sizes
One method to see if the tire pressure you are using is a good number, is periodically perform tire tread depth checks with a tire gauge.
First, establish a good "normal" pressure you want to run. Then using a tire depth gauge, check the tread depth across the tread and keep a record, recording the mileage and depth at each check. Check the depth near the outside edge, the center and the inside edge of the tire tread. Then about every 5,000 miles take another reading and record it.
https://www.tirerack.com/tires/tiret...180902021637:s
Generally speaking and if the alignment and camber is good, you should start to see the depth change. If the edges are wearing faster than the center, your "normal' tire pressure is a bit too low, if the center is wearing faster than the edges, pressure is too high. You can adjust the pressure up or down accordingly, a couple of psi and recheck in another 5,000 miles. When you can check the depth and see the tread is wearing equally across the tread, you have a good "normal" for that vehicle.
It's important to monitor tire pressures during the test so that pressure remains relatively constant to not affect the test. Use a cold pressure setting as the normal.
Good luck... GUSTO
I use a Digital Laser Infrared Thermometer, Temperature Gun, to read tire temps at the track for a quick reading of tire pressures to run on a given day. Equal temps across the tread of the tire is what I'm looking for.
However it's important to take the reading after a relatively long straight stop and not at the end of significant twisties to be sure you get a valid reading. I think the same might also apply with a paint strip.
Good luck... GUSTO
