electric head lights
Old Sep 13, 2018 | 03:50 PM
flyz06 ride's Avatar
flyz06 ride
4th Gear
Default electric head lights
I am changing out my vacuum head lights to electric head lights, I have a 1969 corvette. wondering if anybody has done this
to there car? and if so, can you tell me how the best way to wire the lights to open when turning on, and closing when turning off.
thank you.
Old Sep 13, 2018 | 04:31 PM
Gordonm's Avatar
Gordonm
Here is a good read. I am just doing this now. I bought a kit that someone had never installed. came with a wiring harness.
https://www.corvetteforum.com/forums...c-new-way.html
Old Sep 13, 2018 | 04:45 PM
flyeri's Avatar
flyeri
Richard454 will probably chime in here or you can search for post by him on this topic. I used his brackets, heim joints and instructions. I bought Ford Probe actuators from Rockauto (no core charge) and got actuator arms and harnesses from a Probe in a junk yard. I think I got to diodes from Radio Shack but you can order them on line. While I was doing this I wired my headlights so they are powered from the horn relay bus rather than through the headlight switch. You have to open the wire bundle anyway so why not.
Old Sep 13, 2018 | 05:41 PM
Richard454's Avatar
Richard454
I've put together a PDF on how to do it. Just shoot me and email and I'll be glad to send it to you. richard454 at comcast dot net
As far as wiring- I've made up a male/female plug that simply plugs in between the headlight and factory harness- no cutting up to connect. It brings the headlights up when you turn on the lights and goes down when you turn them off. And it's not affected by high or low beam. I also have made one up that will keep the lights up till you turn off the parking light- say if you want to run halo lights or service/clean them.
A few have used the parking lights to control - HOWEVER-if you turn on the hazard flashers the lights will jump up and down!!!
Another way is replacing the headlight switch with a C4 one- but then you have to run wires all the way inside the cabin.
Old Sep 13, 2018 | 06:24 PM
Gordonm's Avatar
Gordonm
So it is your wiring harness that I got then. I bought it from someone here on the forum not knowing who made up the kit but it must have been you. I have it all mounted up and the relay and harness in. Not permanent but enough to see how it all fits. I have not put power to it yet. I may have a few questions down the road. The brackets and all fit great. The harness looks great also. Should be able to put some power to it shortly.
Old Sep 13, 2018 | 08:24 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
I bought and installed the kit from Richard454 a couple years ago. Works great. So nice to know that when turn on the lights they will actually go up and when you turn them off they go down! What a concept!
Old Sep 13, 2018 | 09:43 PM
Richard454's Avatar
Richard454
Hey Gorden-
just shoot me an email- I have a simple - couple step instructions to easily clock the motors and set the rod length for the final installation.
Thank you Jim!!!!
And they go up and down in unison -quickly!!!!
Old Sep 13, 2018 | 10:34 PM
derekderek's Avatar
derekderek
Cuz let's face it. Vacuum sucks!
Old Nov 28, 2018 | 11:49 PM
mitch.1972vette's Avatar
mitch.1972vette
Richard, does your installation PDF give instructions on which of the vacuum hoses should be plugged off and which should be re-routed in order to keep good vacuum to the wiper door and AC/Heat controls?
Old Dec 1, 2018 | 06:53 AM
oldgto's Avatar
oldgto
Richard454 will probably chime in here or you can search for post by him on this topic. I used his brackets, heim joints and instructions. I bought Ford Probe actuators from Rockauto (no core charge) and got actuator arms and harnesses from a Probe in a junk yard..
Mazda Miata motors are essentially the same as the Probe motors... for those who, like me, couldn`t stand the idea of putting Ford parts on my Corvette!
Old Dec 3, 2018 | 04:47 PM
mitch.1972vette
The kit from Richard ROCKS..... Great stuff. I will be putting mine together first of the year! Thanks Richard!
Old Dec 5, 2018 | 10:10 PM
Strokemyaxe's Avatar
Strokemyaxe
The price of the probe motors are out of this world now. Anyone know where to get some on the cheap?
Old Dec 6, 2018 | 08:08 AM
Rodnok1's Avatar
Rodnok1
I've picked up a set and seen a few other probes/Miata at the boneyards. Place I used charged 15 I think. Went on a half off day and can't remember exactly as had a pile of stuff.
You could look up th closest LKQ u pull it nd see if they have any on hand.(I didn't use a LKQ)
Old Dec 6, 2018 | 12:13 PM
Kevin BC's Avatar
Kevin BC
I have used Richard's kit twice. Once for my own car and second time for a friend.
Second time I purchased a complete kit from Richard with the motors and everything required. saved a lot of time.
Not sure if has motors all the time, but his kit and instructions are excellent.
Only thing you have to figure out yourself is where you want to mount relays and fuses, and make a bracket.
Mine are mounted up under the nose where old vacuum parts were mounted.
Old Dec 6, 2018 | 04:31 PM
80-Vette's Avatar
80-Vette
You have a problem with Ford parts but not Mazda?? So much for the big 2.
Old Dec 19, 2018 | 05:31 PM
oldgto's Avatar
oldgto
I love Ford parts.... on our 65 Mustang and 61 Fairlane. But Ford parts do NOT belong on our Corvette!
Old Dec 19, 2018 | 06:00 PM
Dynra Rockets's Avatar
Dynra Rockets
Ford used to own as much as 33% of Mazda (circa 1994). It is down to 2% equity stake now.
To electric head lights
