1968 Conv needs a frame
Old Sep 18, 2018 | 02:12 PM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
Default 1968 Conv needs a frame
Customer wants to do a driver restoration
The frame is bad in the normal spots
Is the C3 frame the same from 68 up
If no what are the differences
The car is a 427 390 Conv car
Any info or point me to the correct info and I will pass it on
Chris
Old Sep 18, 2018 | 02:31 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by csherman
...Is the C3 frame the same from 68 up...
No. The crash bumper years have slightly different frames.
...The car is a 427 390 Conv car...
Makes no difference for a frame. Transmission makes a difference. AT frames have removable crossmembers.
Have your customer donate $100 to the Forum for professional services rendered.
Old Sep 18, 2018 | 02:44 PM
csherman's Avatar
csherman
I can do that !!!
Old Sep 18, 2018 | 03:08 PM
cdj46's Avatar
cdj46
Chris
There is a small difference 68 core support bolts to the bottom front frame 69-73 bolts to side also the E brake cable on68 goes under frame 69-73 goes through rear cross member.
Old Sep 18, 2018 | 04:04 PM
gbvette62's Avatar
gbvette62
A 68-79 frame is your best bet. Other than the rear crosmember, and the location of some holes, the 68-79's frames aren't all that much different.
An extra pair of reinforcements were added to the kick up area of the frame, during 68, otherwise 68-72 frames are pretty much the same. 73-74 frames are similar, but the body mounts are lower, to accomadate the rubber body mount cushions used starting in 73, and the location of bumper bracket holes changed.
The rear crossmember changed significantly for 75-77, because of the switch to rear bumper impact absorbing shocks, but it's not a big deal to swap the 68 crossmember onto the later frame.
The rear crossmember changed again on the 78-79 frames, and the gas tank crossmember changed, because of the new tank used with the big rear window body.
The 80-82 frames changed somewhat significantly, and take the most work to adapt to an earlier car. The holes for the exhaust pipes were removed from the 80-82 trans crossmember, and the differential crossmember was eliminated all together. 80-82's used the "bat wing" rear that incorporated the differential mount and crossmember, into the rear end itself.
Old Sep 18, 2018 | 05:15 PM
Corvettes by George's Avatar
0Corvettes by George
Former Vendor
I have a couple of good ‘68 4 speed frames
located in South Central Texas
text 210-748-4693
e mail geopar@gvtc.com
Old Sep 20, 2018 | 11:32 AM
csherman's Avatar
csherman
I will pass
To 1968 Conv needs a frame
