L82 value?
Old Sep 19, 2018 | 08:36 PM
rbates74's Avatar
rbates74
Default L82 value?
Whats a useable l82 engine worth?
Or how about just a set of pistons from an l82? Crank and rods?
Old Sep 20, 2018 | 12:19 AM
CanadaGrant's Avatar
CanadaGrant
I sold an L82 out of a 78 a couple of years ago. Long block, never rebuilt with 60,000 miles on it. Ran fine. No carb, distributor or accessories included. $450.
I don't think used pistons are worth anything. Crank is worth a few bucks but not much if anything for used con rods.
Old Sep 20, 2018 | 08:15 AM
stingr69's Avatar
stingr69
Assuming the engine is an original L-82, but worn and needs a rebore - Crank, block, tin, intake, bolts, balancer and smalls are worth something. I know I would buy them. Heads, pistons and rods are not worth much of anything.
Old Sep 20, 2018 | 08:41 PM
rbates74's Avatar
rbates74
Im actually looking to buy an l82 short or longblock for a project
Old Sep 21, 2018 | 12:23 AM
CanadaGrant
Look or put a request in the "C3 parts for sale/wanted" section. Shouldn't be hard to find one.
Old Sep 21, 2018 | 06:03 PM
rbates74's Avatar
rbates74
Was just trying to get an idea about it first.
Old Oct 8, 2018 | 05:51 PM
rbates74's Avatar
rbates74
Looks like two deals fell through... Still looking for a running l82
Old Oct 8, 2018 | 06:02 PM
derekderek's Avatar
derekderek
Why does it have to be an L82? You can buy reman short blocks all over for 6-800 bucks. I mean, I like standard bores and journals. In can see wanting a forged piston-ring engine, but a 40 year old L82 still needs gone through which will make those pistons 30 cents a pound scrap. That engine was special back then cuz there was almost no aftermarket except intakes and cams back then. Now it is an old block and crank.
Old Oct 8, 2018 | 09:48 PM
rbates74's Avatar
rbates74
Junkyard turbo build.
Now if i was an expert tuner i would just use any old small block, but I'm not.
So i need a junkyard engine with forged pistons that will tolerate small mistakes.
Maybe i will be good at it and will try again with a fresh built 383 or maybe i blow it up and i just wasted $600 or $700, instead of several thousand...
To L82 value?
