Hard to replace?
I missed this when I looked over and bought my vette. I believe these are the rear body mounts. They are in a little worse shape than the pictures show and I am a bit nervous. Are they hard to replace?
Thanks in Advance for any input
It depends on whether or not there is underlying damage and whether or not you want to fix it. My body mounts were the same way and there were cracks in the fiberglass pillars as a result. Replacing the caps requires lifting the body off the frame enough to slip the new caps over the pillars. Since my car was off the frame at the time, I cannot tell you how high that is. You will probably have to loosen all eight body mount bolts to lift the car enough. If you search on the forum, you will see that body mount bolt removal is not without risk. I was lucky and didn't damage any of the caged nuts. Also, be aware that when I mated up my new caps, they didn't fit the same way the old ones did, and I had to build up some areas with fiberglass to get them to sit flush. The ottoms of my pillars were not flat either due to pulling against the cage nut after losing support from the cap. Also, the rivet holes didn't line up, which isn't a huge deal if you don't mind drilling new ones. You just hope they're not to close to the old ones.
Yours doesn't look as damaged as mine, but if there is damage under the caps and you want to repair it, I would recommend taking the body off the frame. It's just too difficult to get to everything otherwise. Either way, you are going to have to loosen the body mount bolts. If there is no cracks or damage, you could chose to do nothing and keep an eye on it. Please understand that I'm not trying to scare you off, just giving you a realistic picture. I am on the downside of my resto-mod and that was easily the toughest thing I tackled so far. You don't know what you're going to find when you get those caps off. Here's a couple links to the work I did on mine. Hopefully it will help you in your decision. Mine is one example.
http://www.dans79corvetterestomod.co...rcarriage.html
http://www.dans79corvetterestomod.co...dy-mounts.html
Good luck
MajD
RVZIO
Doing these reinforcements is definitely not a weekend job. In theory, it can be done in a couple weekends if you just lift the body off and support it with 2x4's. The problem is that the car is 50-ish years old, so it's very easy to mess up other things in the process (like twisting off body bolts and such). What should be relatively straight-forward can escalate, depending on your particular car. I got lucky with mine, but it could have easily gone sideways. Also, plan for the "while I'm at it" things like new body mount bushings. If you have a tendency to get carried away (guilty!), this will get very involved
.This is one of those jobs there are a dozen ways to approach. If you decide to tackle it, I strongly recommend spending hours reading people's write-ups. I did a thread on mine once it was done to show the steps I took. Things like using weld mounts instead of rivets and feeding the bolt in backward (ignoring the silly caged nut that always gets destroyed) made the job much simpler.
RVZIO
It's the short tang on the right with a single hole in it. The picture below shows where that is. It's the white, powdery spot near the center of the pillar...all that was left of the aluminum. If yours is corroded through, then the tang remains will be easy to get out.
That square shape is the adhesive that had squished between the mount and pillar during production, and why I mention this. Mine was too far gone to be an issue, but I did remove the splash guard to make the repairs and install the new mounts. The head of that rivet is located in the mount well at the rear of the interior, near the speakers.
MajD
For EMURRAY, what are weld mounts?
https://www.corvetteforum.com/forums...forcement.html
I second the suggestion of cutting the head off and hammering the caged nut out. That's what I did and it worked well.
Mine is a convertible and may be a little different than a coupe. You won't have to deal with getting the decklid hinges out of the way.
On replacing the #4 body mounts, the biggest problem I had was removing the top outer bolt out of the deck lid hinges. The inner ones I got with a 1/2" ratchet box end wrench. The outers there is no room for it. The heads of the bolts face towards the rear of the car and you can not see them, only reach up inside and feel them. I spent about an hour and a half getting the outer bolt out of the right side hinge with a curved wrench.
When I went to do the left side, I thought to heck with this, and I drilled a 1" hole from underneath through the back of the cavity the hinge is in with a hole saw. I then had my friend run a long extension with a swivel socket, that I taped to stay straight, through the hole and I guided onto the bolt from inside the car. Ten seconds later the bolt was out. I will use a 1" plastic plug to fill the hole and when together, no one will be the wiser.
To remove the #4 body mount I first ground off all the rivets from under the car with a cutoff wheel. I ground into the mount itself a ways to make removal easier.
On the back side of the #4 mount is a panel installed by the factory after the mount was installed. You can not get to the rivet holding that tab to grind it off. I first took a screwdriver and got it up between the panel and the mount tab and pried it to get any bonding agent loose from the mount. I then went back into the cabin of the car and center punched the head of the rivet on the back side. I then took a number 10 drill bit and drilled through the rivet, the mount and the panel behind it. I was then able to free the old mount from all it's rivets. I ground all the remaining rivets flush with the body. I used a punch and drove all but the 2 inside rivets out of the body. I took a 1/2" drill and opened up the back of the panel over the rear tab/rivet where the drill came through after I drilled from the inside. I then took a die grinder and carbide bur and cleaned up the hole to give me good access to the rivet when installing the new one.
The 2 rivets toward inside also have a panel install by the factory over them. I ground the bottom of the body that meets the mount bolt area flat and then put the new mount into position. I then inserted rivets into all the holes except for the 2 under the panel. I used the mount for a template and drilled up through the 2 remaining rivets and up through the panel over them.
My car is not stock in any way, so I was not worried about being NCRS correct with my rivets. I used 3/16 heavy duty rivets and a rivet gun. I first put a bottle jack and a wood block under the mounts and put pressure up against the body to make sure they were seated. I pop riveted everything in place. They are not going anywhere now. They sit square and look good without cutting any panels out of the way. There is only a 1/2" hole at the back of the one panel underneath.
Mike
