Gear Ratio
Old Oct 2, 2018 | 12:07 PM
60 SHARK's Avatar
60 SHARK
Originally Posted by theandies
True but it could have been changed over the years.
. So true,, my dif, stamping says it's a 3:36,, but it has a 3:70 inside it,, lol,,
The best check has been stated already,, mark drive shaft and tire, no guessing anymore with silly calculations, ,
Old Oct 2, 2018 | 08:27 PM
sixx27am's Avatar
sixx27am
Finally Got it up in the air today and the rear is stamped LH 3.36 , I also counted the drive shaft rotations to 1 rotation of the tire and it matched 3.36 it is.
Thanks everyone for the input.
Old Oct 2, 2018 | 10:07 PM
caskiguy's Avatar
caskiguy
For your future reference: https://www.gmheritagecenter.com/doc...t-Corvette.pdf
Old Oct 3, 2018 | 07:34 AM
sixx27am's Avatar
sixx27am
Originally Posted by caskiguy
Thanks a million what a great resource!!!
Old Oct 3, 2018 | 06:18 PM
Basque32's Avatar
Basque32
Hi all, haven't been on here for a while, long story...
So my Vette (73 L82 w/Auto) came from the factory with 3.08 rear gears and the numbers on the diff confirm, however, when I'm running 60 mph the tach is at 2700 rpms and it feels like it needs to shift to another gear. Car has BFG TAs that website says the are 27.4" tall but when I put the tape on them they measure 26.5" tall from ground to top of tire. So found this website that seemed to work the best in calculating diff ratios based on tire height http://www.advanced-ev.com/Calculators/TireSize/ and it comes out to be 3.549 so 3.55 gear set which makes more sense to me.
Also I've got a doc named "Vette Diff Ratio" from somewhere but don't remember that says:
You can multiply miles per hour times 1000 and divide by the engine RPM. For a 3.08:1 the ratio is 25.6, for 3.36:1 is 23.1, for 3.55:1 is 22.2, for 3.70:1 is 21.3, for 4.11:1 is 19.2, and for 4.56;1 is 17.0. Do it at different speeds and in different gears and you should get a pretty good average.
Using this info 1000x60=60000/2700=22.222... so from this info my ratio should be 3.55:1 which matches the website's calc.
Anyway, food for thought.
