Gear Ratio
Old Sep 30, 2018 | 11:03 PM
sixx27am's Avatar
sixx27am
Default Gear Ratio
Hey Guys,
My 75 with a 4spd close ratio does 60mph at 3k rpm. Would I be correct in assuming the reared gear is a 4.11?
thanks in advance
Old Oct 1, 2018 | 01:47 AM
Strokemyaxe's Avatar
Strokemyaxe
Originally Posted by sixx27am
Hey Guys,
thanks in advance
Maybe. Right at 3k? Final drive is at 1:1, so if your tires are 26” tall, then you would have a 3.73 rear end.
-Stroke
Old Oct 1, 2018 | 06:58 AM
derekderek's Avatar
derekderek
Use mile markers and the sweep second hand on your watch. And or the GPS Speedo in your phone. The speedometer itself could be off too.
Old Oct 1, 2018 | 07:23 AM
Bikespace's Avatar
Bikespace
Do you trust your tach? The best way to check is to jack both wheels off the ground, mark the driveshaft with tape, and have a helper count the driveshaft rotations as you spin a wheel 360 degrees. I did this, and got 3 and a smidge, so 3.08, which matches what came with my car.
Counting rotations, opening the diff, or nuking it from orbit are the only ways to be sure.
Old Oct 1, 2018 | 08:35 AM
sixx27am's Avatar
sixx27am
-Stroke
The Tach was at 3k , I cant speak for its accuracy though. I did check my GPS and it was at 60 as well so I feel fairly confident in the speedo.
Old Oct 1, 2018 | 11:17 AM
Strokemyaxe
what is your rear tire size?
Old Oct 1, 2018 | 11:38 AM
caskiguy's Avatar
caskiguy
Hey Guys,
thanks in advance
It didn't come with a 4.11
http://www.vettefacts.com/C3/1975.aspx
Old Oct 1, 2018 | 11:40 AM
caskiguy's Avatar
caskiguy
Hey Guys,
thanks in advance
Read this:http://www.badasscars.com/index.cfm/...rod/prd446.htm
Old Oct 1, 2018 | 04:36 PM
sixx27am's Avatar
sixx27am
255/60/15
Old Oct 1, 2018 | 04:45 PM
OldCarBum's Avatar
OldCarBum
Do this^^^^^^^^^^^^^^
It is the best and most accurate way.
It doesn't matter if your tach or speedo are off, you don't need a GPS and it works every time.
Just remember to block the front tires and place the trans in neutral.
Old Oct 1, 2018 | 09:11 PM
EarlyC34me's Avatar
EarlyC34me
Parts Sherpa
255/60/15
yes you likely have 4:11's
Old Oct 1, 2018 | 09:20 PM
60 SHARK's Avatar
60 SHARK
. I have same tire size, and mine has a 3:70 , ,, @ 3000 I'm at 62mph. ,, ,, I don't think he has 4:11
Old Oct 1, 2018 | 09:52 PM
sixx27am's Avatar
sixx27am
i read that but this says 4.11 was an option, not sure which is right.
https://www.corvsport.com/1975-c3-corvette/
Old Oct 1, 2018 | 10:22 PM
EarlyC34me's Avatar
EarlyC34me
Parts Sherpa
i checked bf Goodrich tire sizes and it looks like 27.1 inches so using the formula in the article this is what the tach should read at 60 mph for a 4:11 set up and 3:73 setup
Old Oct 1, 2018 | 10:23 PM
BLUE1972's Avatar
BLUE1972
RPM vs. Gear Ratio and Tire Height
This chart shows you the cruise rpm at 60 miles per hour based on gear ratio and tire height. For maximum performance with less converter slip at the lockup point, your converter's stall speed should stall close to these figures. If the gear ratio and tire size you want to use isn't on the chart, use the following formula to calculate cruise rpm:
MPH x Axle Ratio x 336
Tire Diameter
Rear Axle
GearRatio Tire
......….24" ..26" ..28" ...30" ...32"... 34" ...36" ...38" ...40"... 42".. 44"
3.23 2713 2504 2326 2170 2035 1915 1809 1714 1628 1550 1480
3.50 2940 2714 2520 2352 2205 2075 1960 1857 1764 1680 1604
3.73 3133 2892 2686 2507 2349 2212 2089 1979 1880 1790 1709
3.90 3276 3024 2808 2621 2457 2312 2184 2069 1966 1872 1787
4.10 3444 3179 2952 2755 2583 2431 2296 2175 2066 1968 1879
4.56 3830 3536 3283 3064 2873 2704 2554 2419 2298 2189 2089
Old Oct 1, 2018 | 11:33 PM
OldCarBum's Avatar
OldCarBum
The gear calculator I use says that if he is running 255-60-15 tires, with a 1 to 1 gear in the trans, at 60 mph and 3,000 rpm he should have a 4.11 rear gear ratio.
That is providing his tachometer and speedometer are accurate.
Old Oct 2, 2018 | 12:17 AM
ronarndt's Avatar
ronarndt
Why not just get the rear axle code off the differential? This will tell what the gear ratio was that came from the factory. The various calculations here for tire size don't help much. The speedometer displays speed by how many revolutions the transmission makes- it does not care what the tire size is. BTW- 3000 rpm on my 68 convert reads 60 mph on the speedometer. Actual speed due to my oversize tires on 20 inch rims is 68 mph by GPS. I have a 3.36 posi rear axle.
1968 axle codes: CODE RATIO AK 3.36:1Standard (327/350) AL 3.08:1Positraction (327/350) AM 3.36:1Positraction (327/350) AN 3.55:1Positraction (327/350
1975 axle ratios:Standard rear axle ratio3.36:1 Optional rear axle ratio3.70:1, 3.08:1, 3.36:1, 3.55:1
To Gear Ratio
Old Oct 2, 2018 | 12:42 AM
C3 Stroker's Avatar
C3 Stroker
That is correct. I have 255-60-15 tires and a 4.11 rear gear. My speedo reads 60 mph at 3100 rpm, auto trans.
Old Oct 2, 2018 | 05:49 AM
theandies's Avatar
theandies
Looks like 4.11
Try this:
Gear Ratio Calculator
Old Oct 2, 2018 | 05:51 AM
theandies's Avatar
theandies
True but it could have been changed over the years.
