'79 Windshield Washer Problem
Old Oct 10, 2018 | 05:00 PM
Fastclient's Avatar
Fastclient
Default '79 Windshield Washer Problem
When I bought the car the washers did not work but thought I could deal with it later. So today I dropped the reservoir out the bottom and to my surprise there was no washer motor or any loose wires that looks like they would attach to the motor. I bought a new motor, installed it in the bottom of the reservoir but now my dilemma is what wires attach to the motor. I do see two short clipped wires coming out of the wiring harness plug. One (I believe) pink and one yellow. Any help would be appreciated. Thanks!
Old Oct 10, 2018 | 06:46 PM
SwampeastMike's Avatar
SwampeastMike
In the '79 the washer pump is powered by a white wire (+12V ignition from the WIPER fuse) and pink wire (ground provided by the wipe/wash switch). Since white often discolors to a yellowish color you have likely found the proper leads.
In '79 the wires for the washers are white (+12V ignition from the WIPER fuse) and pink (ground from the wash/wipe switch). Since unwrapped white wires often turn to a yellowish color you've probably found the proper ones.
The only other nearby wires in '79 are for the cruise control (brown and white) and the alarm horn (yellow and orange).
