Help with a Holley
Being that this is my first carborated car, I am years behind on the learning curve.. Heres whats going on
I have a 78 L48, she came with an Edelbrock performer intake as well as an Edelbrock carb.. While working on the car we realized several issues with the Edelbrock, so its gone. In its place, a gifted Holley 4160 600CFM 80457 Carb... Hooray! Im in the Holley Club!
OK, thats where the fun ended.. I realized that after i got the old carb off, scraped at old gaskets for an hour, got my new gasket on and holley mounted, that I had no f'in idea what to do from there. I hooked up the choke, hooked up dist. vacuum, and gave my best uneducated guess at hooking on trans/throttle cabes/springs (this is why i said dont laugh!!
If this looks correct to everyone so far, which i doubt it does, I have a few more questions..
Where does my brake booster get hooked into?
Where does my manifold vacuum line get hooked in?
I know i still need to hook up the fuel line - thats a problem for another day.
Thanks for being gentle, and type slow so I can keep up!
Pic #1 - You have your vacuum advance on a ported vacuum source. Move it to the nipple under the front bowl (visible in pic 2....timing will be required)
Pic #4 _ The big nipple under the secondary diaphragm is where you want to connect your booster hose (it's manifold vacuum)
Fuel hose to the banjo fitting and fire it up!
When i was looking into the port under the secondary diaphram, people said that was the PCV and not to connect the booster there which is why I avoided it - but if you say its good 2 go, ill give it a shot once i buy a longer vacuum line!
Also, do my connections look ok with the spring/throttle cables and such?
https://www.jegs.com/InstallationIns...0-0-80457S.pdf
The manifold vacuum tree i ended up purchasing was Right Stuff Detailing Vacuum Fittings IMF6707, and then went to the local hardware store to get a female thread adapter to fit my brake booster line on to (so i have brake booster, trans, and headlight vacuum on the same tree). Moved PCV to passenger side and then put my fuel line on (Holley part 26-29). Fired right up.
^ good catch! You want the PCV to introduce vacuum in the oil chamber which causes air to be pulled in on the vent from the other side of the engine. By having a vent/breather on the same side of the PCV, the vacuum only exists really on that side, and within the valve cover.
