rotor holes
Old Oct 14, 2018 | 06:31 PM
teamo's Avatar
teamo
Default rotor holes
Took the old front rotors off and I found several holes drilled in the hat. I've never seen anything like this before. Looks like it was done at a factory or at least someone had some good drilling equipment because the holes are perfectly aligned.Attached Thumbnails
Old Oct 14, 2018 | 06:54 PM
kansas123's Avatar
kansas123
Put in there to keep rotors from getting (too) hot? Never saw it before either....
Old Oct 15, 2018 | 07:43 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by teamo
...Looks like it was done at a factory...
Maybe, but not GM.
Old Oct 15, 2018 | 11:32 AM
kansas123's Avatar
kansas123
You take these off the front or the back???
Old Oct 15, 2018 | 12:11 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I've seen holes like that, before, on OE rotors, but don't remember what car, and in all honesty, didn't really give it a second thought. Balance holes, maybe??
Old Oct 15, 2018 | 03:25 PM
danh77's Avatar
danh77
Mercedes used to do that on some rotors, sold em but never inquired the purpose
Old Oct 15, 2018 | 08:01 PM
teamo's Avatar
teamo
I took these off of the front. They were riveted to the hubs. One had the holes and the other side did not.
Old Oct 15, 2018 | 09:47 PM
kansas123's Avatar
kansas123
Like Leadfoot4 said, could also be for balance purposes, and I also think for heat dissipation....
To rotor holes
