help - Factory Information
Old Oct 26, 2018 | 10:59 PM
chumaruiz's Avatar
chumaruiz
4th Gear
Default help - Factory Information
Hi, i want to restore my c3 , to the original color , etc
i just have the VIN number, how can i know what was the original color, engine, etc?
thanks!
Old Oct 27, 2018 | 12:28 AM
Z06LMB's Avatar
Z06LMB
The VIN won’t help you to answer these questions, but there is a metal plate on the door jamb, driver’s side that identifies the exterior and interior colors. Only the build sheet or the dealer invoice shows what your car was born with from the factory. What year is your Corvette?
Old Oct 27, 2018 | 12:38 AM
CanadaGrant's Avatar
CanadaGrant
You're going to have to supply a little more information. The year to start. When you open the drivers door there is a plate riveted to the body just above and inside the top door hinge. What does it say? That has the original color. On the engine block just in front of the passenger side cylinder head there is a flat surface on the block with two sets of numbers. What are they? One set will tell you the engine plant and what it is and the other will have a derivative of the vin number if it is original (or not) to the car. If the engine has been rebuilt at one time that might be missing. There are also casting dates on the block, heads and most other parts but you need to provide something and pics if you have them.
Edit: I see Z06LMB beat me to it! Takes me 10 mins. to type a couple of sentences... By the way, welcome!
Old Oct 27, 2018 | 01:16 AM
OldCarBum's Avatar
OldCarBum
Depending on the year, the VIN will tell you if your C3 was a small block or big block.
Old Oct 27, 2018 | 09:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Original interior and exterior color codes, along with the time built date, are on the trim tag on the driver's door hinge post. St. Louis shown.
Bowling Green tags have a different format, but the color and trim information is still there.
Old Oct 28, 2018 | 12:54 PM
chumaruiz's Avatar
chumaruiz
4th Gear
hi, thanks its a 1969 coupe, im just to buy, its looks thats its a 427 block. its not running, so im trying to check if its a 427 vette,
and i would to restore it to the original condition, ext color, int color, and options.
how can i check that?
whats good price for the car? , ins need pretty much to restore everything
thanks!
Old Oct 29, 2018 | 11:34 AM
OldCarBum's Avatar
OldCarBum
Pictures would be needed.
Check birdcage and frame rust.
Old Oct 30, 2018 | 08:18 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by chumaruiz
...i would to restore it to the original condition...and options...how can i check that?...
You will need factory documentation with the car or the tank sticker in order to determine the options the car came with, including the optional big block engine. Ask the seller for any paperwork he/she may have on the car.
To help - Factory Information
