muncie oil topup
Old Nov 1, 2018 | 01:00 PM
Dave Vincec's Avatar
Dave Vincec
Default muncie oil topup
hi all,
I feel somewhat silly asking this question... but since I recently broke an aluminium part trying to unscrew a seized plug, I figured I should make certain before I brute force it the wrong way!
With the gearbox in car - which way should the top up plug on the side unscrew? - eg: should I be pulling the wrench towards the front of the car or the back?
thanks for thoughts!
David
Old Nov 1, 2018 | 01:13 PM
cor66vette's Avatar
cor66vette
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
Righty tighty - lefty loosey.
Old Nov 1, 2018 | 01:22 PM
Dave Vincec
Yep.. just having a mental block, when lying on my back under car as to which way is which given orientation of gearbox/plug etc..
Old Nov 5, 2018 | 02:19 PM
Dave Vincec
So.. paranoid confirmation question..
is 'lefty loosey' the right orientation when you are under the car, looking up at the box from underside? (From passenger side)
mindful that if you were on top of the box, left would be the opposite direction... or drivers side.. :s
Old Nov 6, 2018 | 07:38 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
While FACING the gearbox, from the passenger's side, because that's where the plugs are located, "lefty" would have you twisting the wrench handle toward the back of the car (turning counter clockwise).
Old Nov 6, 2018 | 07:42 AM
joewill's Avatar
joewill
loosen = counter clockwise
tighten = clockwise
Old Nov 6, 2018 | 01:47 PM
CanadaGrant's Avatar
CanadaGrant
tighten = clockwise
Your water bottle (or anything else in the fridge) works the same way. Position it the way you are looking at it on the car and it will be the same.
To muncie oil topup
