NCRS judging manual wrong again?
Old Nov 7, 2018 | 09:15 PM
62corvette's Avatar
62corvette
Default NCRS judging manual wrong again?
According to the NCRS 70-72 manual, 72 had only one horn from the factory. It must be wrong, because the 72 I just bought had three and the previous owner had it for 40 years and they didn't say they changed anything. Plus, the green wire that ran from the horns under the car to the relay in the battery box was the same green color that GM used for other wiring. I am convinced that they are wrong again.
Old Nov 7, 2018 | 11:00 PM
7T1vette's Avatar
7T1vette
The A.I.M. is pretty clear that it had just one horn and it was electrically activated. What is on your car are three horns that are compressed air activated...and a compressor.
Old Nov 7, 2018 | 11:08 PM
C8H18's Avatar
C8H18
Yeah - I think someone is kidding here...
But just in case - the transition to one horn is also mentioned in either the service bulletin or the service news sections of that same NCRS manual.
Old Nov 7, 2018 | 11:19 PM
The13Bats's Avatar
The13Bats
Hey, what are you gonna do with that 3 horn set up, dont toss it out,
i would love to install it on my modded 69
Old Nov 8, 2018 | 12:23 AM
Richard454's Avatar
Richard454
April Fools in November?
Looks like some Vintage Hella Air horns
Old Nov 8, 2018 | 09:10 AM
Randy M's Avatar
Randy M
Mike,
You're a card. Glad you are having fun with it.
Old Nov 8, 2018 | 10:40 AM
crawfish333's Avatar
crawfish333
CI 6-7 & 9 Veteran
Mine came with 2 sets of horns, one under the hood and one that looks like this one on the front hood. I think the one on the front hood could have been a dealer installed option.
Old Nov 8, 2018 | 01:14 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
I had a 49 Murc that had the 3 horn with the compressed air system.
I may know some guys that would love to get that horn setup.
Old Nov 8, 2018 | 04:14 PM
jim2527's Avatar
jim2527
Does it have the 'big rig' sound or a 'dukes oh hazzard' sound?
Old Nov 8, 2018 | 04:19 PM
jim2527's Avatar
jim2527
Old Nov 8, 2018 | 04:24 PM
oldgto's Avatar
oldgto
"La Cucaracha"
Old Nov 8, 2018 | 09:19 PM
C8H18's Avatar
C8H18
...well there's also the factory alarm horn in the rear
Old Nov 9, 2018 | 12:29 AM
orourke's Avatar
orourke
Good one.
Old Nov 9, 2018 | 07:08 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Looking at my AIM I can see that is not original. The factory horn had a blue wire, not green. �� Also it played “Hello Dolly”.
Old Nov 12, 2018 | 03:56 PM
talley1968's Avatar
talley1968
I bought my 1968 in May 1970 from the original owner. It had zero modifications when I bought it. NCRS says it should have two horns but mine has three, all behind the grill and all painted in the original flat blackout paint.
Old Nov 13, 2018 | 02:42 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by talley1968
...NCRS says it should have two horns but mine has three, all behind the grill and all painted in the original flat blackout paint...
FWIW: horns were installed after blackout and not mounted behind the grilles.
Old Nov 13, 2018 | 03:31 PM
7T1vette's Avatar
7T1vette
GM/Chevrolet would never have approved locating the horns [or anything else] behind the grill, as those were NEEDED passages for airflow thru the radiator (along with the airdam-directed airflow up and thru the lower valence. Cooling airflow was an "issue" to begin with. It was surprising enough that the 'parked' headlamp buckets and the black plastic shields for them contributed to barely-adequate airflow.
To NCRS judging manual wrong again?
