Low fuel light Reset....?
Old Nov 16, 2018 | 05:17 PM
San Diego Ron's Avatar
San Diego Ron
Default Low fuel light Reset....?
Car back together after tearing dash out to replace brake booster. There had been several burnt out bulbs, I replaced all, once battery connected and car started Low Fuel light was lit...for good reason, was about on empty. Added 5 gal. of fuel which brought gauge up but light is still lit, is there a reset or do I need to add a certain amount of fuel? Some say they can change a booster in 10 minutes...me, about a week but happy it is done and a lot of things fixed and cleaned up under there.
Old Nov 16, 2018 | 05:44 PM
righthanddrive's Avatar
righthanddrive
Did you just insert a bulb into the socket for the low fuel, or does it have the circuit board with light ?
Old Nov 16, 2018 | 05:47 PM
San Diego Ron
Just the bulb
Old Nov 16, 2018 | 06:03 PM
righthanddrive
It needs a module to work correctly
Old Nov 17, 2018 | 09:54 AM
San Diego Ron
Thanks "righthanddrive" but don't know what that is or where it would be located, was not lit before pulling dash but could have been burnt out bulb, had quite a few not working.
Old Nov 17, 2018 | 11:57 AM
The13Bats's Avatar
The13Bats
The low fuel socket actually has 3 contacts, the little brain board twists into psnel with a bulb in it ,
Wilkcox sells a replacement that is better than orginal that you cant get anyway.
Old Nov 17, 2018 | 12:14 PM
bmotojoe's Avatar
bmotojoe
If you don't have the module, just remove the bulb. I repaired my bad module and at about 3 gallons in tank the light comes on.
Original Low Fuel Module, Bad transistor marked in green
Old Nov 17, 2018 | 02:32 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
It is possible to access the fuel board through the glove box opening. Just take the box out.
To Low fuel light Reset....?
