1978 defroster
If my memory serves me correctly the relay is on a timer (so-to-speak) and it ill shut off when certain parameters are met. So using it in on hot day...it will not work due to it is too hot out.
Do you have a factory service manual for your car????
DUB
"A control switch activates the system and allows current flow through the rear window grid for approximately 8-12 minutes. A defogger timer, which is also activated when the switch is depressed, automatically shuts off the system. The system can be turned off at any time by momentarily pushing the control switch to the OFF position. The system is protected by a 10amp fuse and a circuit breaker located in the fuse block. "
You can simply test and see if you have a GOOD ground going to the grid...and then also see if you get 12 volts when you turn it on.
Often times I will CAREFULLY remove the power wire and check it when it is disconnected...then attach it and see what happens.
IF you have NO pwoer going to it when you turn it on ....or....you do not have the other wire grounded...ti will NOT work.
IF my memory serves me correctly the wire will be about a 12 gauge BLACK wire with a red or orange stripe of it. If it does that is your 12 volt wire. The wire on the other side will be a 12 gauge SOLID back wire with no stripe on it.
DUB
