I have a very low mileage 69 roadster and I understood that the car came originally with red strip tires, however we just pulled the spare out for the first time, it was unused, and it is a white stripe. Does this likely mean that it came with the white stripers or did GM put the white striped tires in as spares routinely? Does anyone know?
Red stripes and white stripes were both available on the '69, for $31.30 (code PT6 and PT7, respectively). "At the end of the summer of 1969" Chevy added raised white letter tires to the option list for $33.15. (Quoting from Tom Falconer's "Collector's Originality Guide, Corvette 1968 - 1982".) All of these were either Firestone, Goodyear or UniRoyal.
The closest I can come to answering your question is that the NCRS guide for 1970 - 1972 Corvettes reports that all five tires matched when they left the factory on those model years, I don't have the NCRS guide for 1968 - 1969.
I know it would certainly bum me out if I bought a new Corvette in 1969, got a flat, and ended up with 3 red stripes and 1 white stripe. So seems like Chevy would want to give everyone five matching tires.
If anyone has the NCRS guide for 1968 - 1969, it probably has the definitive answer to your question.
Check the date code on that spare tire. If it matches when the car was built, it likely is the original spare and the other tires were 'white stripe' tires. If it has later date code, the car could have come with red lines (or white walls....or RWL....or stock 'blackwalls'). Thirty bucks was a lot for upgrade tires back then; it cost less than $10 to go from blackwalls to whitewall tires if you bought a new set at a tire store. Of 39K C3 vehicles built in '69, 10K of them had blackwall tires!!
I'm curious - how did you come to understand it came w/ red stripes originally?
I'd second the matched 5-set tires being installed - that's always been my understanding anyway. As to what was 'likely' installed beyond the clear hint from the 'new' spare - statistically the white striped tire was by far the most popular tire installed at the factory in 69. A distant 2nd would be black walls and so on.
DOT did not require date of tire manufacture until 1971, so you won’t find it on an original ‘69 tire. I didn’t find it on the original spare tire on my Sept ‘69 car.
According to the latest TIMJG, tires made after 01/01/68 must have a DOT stamp, per federal law. GM started using DOT stamped tires before this date, but some very early 68's may not have them, but instead a white sticker with reddish-orange lettering.
From: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
If the spare is a WW tire the Corvette came with WW tires unless you have real paper work showing otherwise. ALL 5 tires were the same.Probably another case of buying the story.
