Floor Jack Recommendations
Old Dec 2, 2018 | 11:33 AM
fastimes's Avatar
fastimes
St. Jude Donor '19-'20-'21-'22
Default Floor Jack Recommendations
Hi all,
This may seem like a silly question, but . . .
I have to go out and buy a floor jack. I sold mine before my move to Nevada.
My daily driver is a Jeep Wrangler, so the jack I had was a high-lift model. Now for my C3, I'm thinking I may need a "low-profile" jack.
I would certainly prefer one floor jack for both vehicles, so I'm hoping I can get by with a standard profile 3-ton floor jack. Any suggestions?
I would like to avoid spending a fortune on one, being so close to the holidays.
Input is appreciated as always.
Old Dec 2, 2018 | 11:37 AM
CamarosRus's Avatar
CamarosRus
HARBOR FREIGHT...........The newer YELLOW ones they have
Old Dec 2, 2018 | 12:03 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I used Harbor Frieght aluminum which is a good value and often on sale.
Old Dec 2, 2018 | 01:28 PM
Devs77's Avatar
Devs77
Quickjack if you have the money for one. Got mine a few months ago and I love it!
Old Dec 2, 2018 | 01:51 PM
449er's Avatar
449er
CF Community Team
Harbor Freight has some inexpensive long reach low profile models, that's the way to go on a budget
Old Dec 2, 2018 | 02:08 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Yep......I went and got one.......with the coupon it was $179.00
They cannot keep these on the shelf. It works as good as the Snap On as my buddy has the jack they cloned it from.
https://www.harborfreight.com/3-ton-...uty-63183.html
Jebby
Old Dec 2, 2018 | 02:09 PM
pws69's Avatar
pws69
Completely agree! I purchased one of these a few months ago and it is real nice. Very rugged and grease fittings on key joints!
I have always considered HF as a "light duty, use once and toss" place (handy and fun to browse the "stuff") - however - I recently purchased their Vulcan ProTIG 200 Welder and it is quite nice also!!
Surprise, surprise!
Old Dec 2, 2018 | 05:35 PM
How Are You's Avatar
How Are You
QuickJack 5000. I love mine!!!
Old Dec 2, 2018 | 06:02 PM
caskiguy's Avatar
caskiguy
Jebby
It has a lift height of 23 1/8" inches !
Old Dec 2, 2018 | 06:34 PM
oldgto's Avatar
oldgto
We also went with the Harbor Freight 3 ton.... with cross beam. Works great for lifting the Vette one side at a time, bringing both wheels off the ground at the same time. AND for lifting the front or rear on a more stable platform than a single point of contact.
Old Dec 2, 2018 | 08:05 PM
JoeMinnesota's Avatar
JoeMinnesota
Mine crapped 2 summers ago, so I picked this one up at Walmart. Nice and low and has worked like a champ:
https://www.walmart.com/ip/Torin-Jac...3505W/14560043
Old Dec 2, 2018 | 09:09 PM
peyc2's Avatar
peyc2
I bought the blue Harbor freight aluminum and just didn’t feel safe with it
i returned it and bought the yellow Dayton 3 ton low profile
it is mulch heavier at 110lbs but it can do a high lift from the front crossmembe no problem then placed on jack stands
The lifted the rear from diff and placed on 2 more stands works great, I just felt the other jack was weak and I was af
afraid of it flexing
Old Dec 2, 2018 | 09:37 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
https://www.harborfreight.com/automotive-motorcycle/floor-jacks/3-ton-long-reach-low-profile-steel-heavy-duty-floor-jack-with-rapid-pump-64241.html
low profille and long reach
The quick jack cant be beat if its in your budget but a jack is indespensible
https://www.costco.com/CatalogSearch?dept=All&keyword=quick+jac k
Old Dec 2, 2018 | 11:47 PM
fastimes's Avatar
fastimes
Thanks to all for the great recommendations. I was actually surprised to see how many folks own Harbor Freight floor jacks.
I opted for the steel low-profile 3-ton model. I had a coupon that knocked a few bucks off, so that helped.
It seems to be built quite well and should work for my needs. Low enough to fit under the C3 and high enough lift to get my Wrangler off the ground.
2 7/8" minimum height and 19 1/2" maximum.
Old Dec 3, 2018 | 01:49 AM
John 65's Avatar
John 65
That's the 3 ton I have for 5 or 6 years now and it has worked perfect. Very happy with it.
Old Dec 3, 2018 | 06:04 AM
Wee's Avatar
Wee
I have 2 of the one pictured in post #14 above....No issues, I have had one of those over 5 years.
Brian
Old Dec 3, 2018 | 09:45 AM
74Ken's Avatar
74Ken
Brian
So did I, mine is re-sold as a Michelin low profile one, Works great on the 4" clearance on the vette and it even lifted my avalanche.
Now it lifts my wrangler with a 2.5" lift also.
Ken
Old Dec 3, 2018 | 11:34 AM
fastimes's Avatar
fastimes
Wow, now that I have my floor jack, I'm searching the forum for the proper placement of the jack and jack stands.
Now I'm nervous about screwing things up. I've read about body flex, doors being knocked out of wack, front alignment being affected by improper jacking.
I've lifted many cars in my day, but being a C3 newbie, I must admit, I'm a tad worried about this one.
To Floor Jack Recommendations
