Speedometer Driven Gear
Old Dec 14, 2018 | 09:41 PM
BlueL82's Avatar
BlueL82
Default Speedometer Driven Gear
What is the stock gear count for a 1980 L82? Stock rear end and I pulled a 23 tooth gear out of the trans. Not sure if it was the right one, speedo was barely readable with how much it jumped. Could an incorrect gear cause the jumping I was experiencing? Transducer is working and new cable, haven't had chance to test them though with the trans all apart.
Old Dec 17, 2018 | 07:47 PM
TimAT's Avatar
TimAT
If the driven gear adapter is plastic, hunt down an aluminum one.
Old Dec 17, 2018 | 08:31 PM
drwet's Avatar
drwet
I don't think the speedo gear would cause that problem. More likely a sticky cable, or a problem with the speedo head itself.
Old Dec 17, 2018 | 09:54 PM
BlueL82's Avatar
BlueL82
23 tooth turns out to be the wrong size and the hole for the end of the speedometer cable was completely worn out. Ordered a new 8 tooth drive gear and a 19 tooth driven gear.
To Speedometer Driven Gear
