TH400 vacuum modulator
Old Dec 15, 2018 | 06:20 PM
Jim71Vette's Avatar
Jim71Vette
Default TH400 vacuum modulator
I think this modulator is original. While the transmission is out, can it be tested?
If it needs to be replaced, what is the best replacement?
Old Dec 15, 2018 | 09:38 PM
Motorvation's Avatar
Motorvation
Pull a vacuum on it. Shouldn't bleed off. Replacement: Red stripe, adjustable.
Steve O.
Old Dec 16, 2018 | 02:02 AM
7T1vette's Avatar
7T1vette
If your transmission is shifting properly, it's fine. When it fails, the tranny won't shift ranges until it's wound up pretty tight. Also, if you just pull off the rubber (vacuum line) hose, you will likely get trans fluid coming out (bad diaphragm). You will definitely know when it fails.
I would keep the original modulator in there as long as it's willing to work OK.
To TH400 vacuum modulator
