Paint/Primer question
Old Feb 1, 2019 | 09:39 AM
jrob56's Avatar
jrob56
Originally Posted by DUB
If I understand what you are asking ...and that is IF you take off your original fenders and put new ones on...and blend the paint into the hood, doors, bumpers,etc.....WILL the factory fender look different F you take off your NEW fenders and put the originals back on...and the answer is YES...the color can be off DEPENDING on how well the color matched BEFORE you blended in the new fenders.
I have painted two hoods for people due to they wanted the original painted along with a custom hood so they could switch them out if they wanted to. SO...possibly painting the originals at the same time as you blending on the new fenders is what will be needed to make sure they match when and if you swap them back out....BUT....this also depends on how long you wait to do this...because if you wait ten years and the car is out in the sun and all that...then the chance the cars paint job has faded so the fenders you did paint will not match anyway when you put them on.
DUB
Not sure how this got on this thread, was trying to reply to a guy that was asking about adding wide fenders and whether to blend or butt them. Thanks though, sorry for the confusion.
Yep, you nailed it, didnt consider the fading. Guess that would depend on if garaged and how much time it spent out.
Old Feb 1, 2019 | 01:57 PM
71 Vert LS1's Avatar
71 Vert LS1
It's funny the comments on using power tools. When I was painting my C10 last winter at a body shop I did all the sanding by hand. The body shop owner who was supervising me said I didn't have the "skills" to run power tools. He said they would just get me in trouble.
Old Feb 1, 2019 | 06:50 PM
DUB's Avatar
DUB
Not knowing what was needing to be done or any of that....
it is a crying shame he did not believe enough in your ability to comprehend instructions. And at least allow you to use it. Just because a power tool has a trigger that allows it to spin up to maximum RPM speed.....does NOT mean that it has to be run at that speed all the time to make that tool effective and a time saver. WE ALL never knew how to use power tools until we did use it. If a person is WATCHING what they are doing and PAYING ATTENTION...they can help greatly. Obviously he did not have the confidence in his ability to instruct a person on how to use it or felt it was not needed.
But to also comes to his defense......there are jobs that do not require the use of a power tool and it is actually faster to do it by hand and NO FEAR of creating more problems.
DUB
Old Feb 1, 2019 | 10:03 PM
71 Vert LS1
I should of said I've never done any body work prior to this project. I made the body shop guy aware of this. He was a friend of a friend of a friend that likes projects but has to run a money making collision shop. Can't be looking over my shoulder every second. I think one of the reasons he didn't let me use power tools was to see if I was really up to task of doing all the work required. And yes the sanding is very good for the upper shoulder muscles. I'm recently retired so I did have the time. We had more than a few conversations about body work. Why he did this or that on cars he had in the shop. I learned a ton in 6 months. He said that power tools tend to remove too much material too fast so then you have to reapply.
Anyone who has sanded all day know how good a cold one tastes at the end of the day.
Old Feb 2, 2019 | 03:45 PM
roboto65's Avatar
roboto65
Got up to my buddies and put a test sand on it and it sanded pretty good. I have some Durablocks ordered and some flexible ones also. I also have a 6 inch Orbital air sander if it does not look right I will take it all off and start over probably the best idea but we will see will have many more question I am sure DUB and all Thanks for helping so far.
While I am asking questions to fill low spots is Evercoat the “best” choice as fillers go for fiberglass and plastic ?
Old Feb 3, 2019 | 11:54 AM
DUB's Avatar
DUB
For what it is worth again:
Using a orbital sander to take down the primer to the body is DO-ABLE due to I can do it without FEAR of damaging anything because I know how to use the sander correctly. AND...I also know I am going to prime it so I am not so concerned about every little thing due to the type of primer I am using will cover a vast majority of minor issues.
I am assuming you are removing the primer. So the choice of body filler to repair things may change depending on if the part is fiberglass or a flexible rubber part.
I know I use Vette Panel Adhesive ( Evercoat part number 100870 quart or 100880 gallon) for all filling on a car like yours where the repair is NOT a structural repair requiring bonding. Even though they sell some of the soft catalyzed glazing putties...I do not use them due to they are soft and I prefer to stick with the VPA for all fill work. Even if it is filling in pinholes.
Call Evercoat if you go to buy the VPA so you can read the date code to make sure you are getting good stuff that is not out of date. It is not that hard to use if you know how to use it but it is different so if you get it...let me know so I ( or others who know about it) can aid you in how to use it so it does not frustrate you.
DUB
Old Feb 3, 2019 | 09:22 PM
71 Vert LS1
My fault for thinking about what the OP had originally asked. I showed the pics to the body shop guy I used and he said without knowing what primer is used he would not hesitate to sand it all off and start over. He said a DA sander used carefully as DUB said would work well. After that body work, spray poly filler and then 2-3 rounds with high build primer.
Good luck with your project.
