Distributor Cap?
Old Dec 24, 2018 | 02:50 PM
Midyrman's Avatar
Midyrman
Default Distributor Cap?
Can anyone tell me the part number for the Delco Remy cap for a 1970 LT-1. There is also a number on the top of the cap.
Thank you.
Old Dec 24, 2018 | 03:50 PM
gbvette62's Avatar
gbvette62
The correct AC Delco distributor cap is the D308R. This cap was used on all Corvette V-8's from 1962 till 1974, and some earlier Chevy V-8's. The caps originally said "Delco-Remy Patent Pending" on the top of them, but the cap currently available from Delco has no markings on it. There is a repro cap with the correct markings on it available from most Corvette vendors for about $50.
Old Dec 24, 2018 | 05:11 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
the same cap was used on ALL Chevy V8 cars and trucks and maybe International trucks with V8
Old Dec 25, 2018 | 07:18 AM
Midyrman's Avatar
Midyrman
Default Thank you.
Merry Christmas!
Old Dec 25, 2018 | 09:25 AM
3X2's Avatar
3X2
That is not totally correct. The L88 & ZL1 used a dark brown cap. For the OP, the cap would be black With Delco Remy Patent Pending in a circular pattern around the center tower. Some original caps may have a R after Patent Pending. There should be a reinforcement that runs vertically about 3/4's the way up the right side of the window from the base of the cap.
Old Dec 25, 2018 | 09:37 PM
Midyrman's Avatar
Midyrman
Default Cap
Looking in eBay, there are a couple used caps with Patent Pending, and many with only Patent followed by a series of numbers. The ones with Patent Pending say the application runs up to about 1967-69 depending on the auction. Are they correct? Since I may have the car NCRS judged some day, I might as well get it right the first time.
Which one is correct for my ‘70?
Thanks.
To Distributor Cap?
