Squealing belt
Old Dec 31, 2018 | 11:33 AM
nutsy's Avatar
nutsy
Default Squealing belt
i have a belt squealing really bad when I rev up my 454. Any tricks on how to eliminate or figure out which one is noisy? They seem tight enough. Car has AC PS also. Thanks Nutsy
Old Dec 31, 2018 | 11:48 AM
BLUE1972's Avatar
BLUE1972
If a belt slips enough it can get polished. Sometimes you can clean the belt and clean the pully with solvent (damp rag) , 120 sandpaper. Do not get sand from the paper into the bearings.
If the belt has a good amount of oil or antifreeze on it it's usually done.
Old Dec 31, 2018 | 11:57 AM
BLUE1972's Avatar
BLUE1972
This may help, be sure all the guides and tensioners are there.
Old Dec 31, 2018 | 03:47 PM
HeadsU.P.'s Avatar
HeadsU.P.
Usually flipping the belt 180* (opposite rotation) will take the "set" out of the rubber and you will be good for another few yrs. Those pulleys seldom spin perfectly parallel and have just enough tilt to glaze one side of the belt more than the other edge. Flipping it puts the glaze on the other edge of the pulley.
Old Dec 31, 2018 | 05:51 PM
drwet's Avatar
drwet
I tried a cogged belt a few years back and couldn't get it to stop squealing. Swapped it for one without the cogs and that solved the problem.
Old Dec 31, 2018 | 06:17 PM
derekderek's Avatar
derekderek
It's always the alternator. It's just difficult to get that belt tight enough.
Old Dec 31, 2018 | 07:19 PM
Sayfoo's Avatar
Sayfoo
Good advise above. I've used acetone to get the glaze off.
Make sure you have the correct width belt. Some are thinner than others and don't ride the pulleys right.
I had a brand new belt squeal right off the bat. Got a different brand and it worked well. The second one was noticeably softer than the first.
Over tightening is tough on the bearings.
Old Jan 1, 2019 | 06:23 AM
mrvette's Avatar
mrvette
I noticed over the years that these old cars have the pulleys at a full 1/2 inch belt width , newer belts are metric and more narrow, also the pitch of the V is different, the new belts tend to ride on the upper portion of the V on those old pulleys, so the belts slip, look close at your belts, they set lo down in the old pulleys, and look at the friction surfaces, bet you will find the upper sections of the V are taking the wear.....and the backside of the belt is fraying on the edges and somewhat of a divot/U shape across the backside.....
Witch is why I switched to a serp drive many years ago..... although IF you spec an old American size belt, you could still find them, 20 years ago, NO bets on today.....
Old Jan 1, 2019 | 10:39 AM
henrikse's Avatar
henrikse
bar soap hold on belt when moving
Old Jan 1, 2019 | 11:15 AM
kansas123's Avatar
kansas123
I remember doing that back in the old days hahaha
Old Jan 1, 2019 | 11:22 AM
hope2's Avatar
hope2
exactly, I use Ivory which is pure soap, if that matters. Simply touch the inside of the belt with the bar and squeak will go away or certainly change
Old Jan 3, 2019 | 04:12 PM
joewill's Avatar
joewill
power steering belt on a 454 is extremely hard to tighten or work on. that is the one mostly neglected.
Old Jan 3, 2019 | 04:38 PM
BLUE1972's Avatar
BLUE1972
Not when you have one of these
Old Jan 4, 2019 | 06:36 AM
nutsy's Avatar
nutsy
Default Belt
yes, it’s a pain to tighten, had to put on ramps and do it from the bottom, that was the one squealing, all good now.
Old Jan 4, 2019 | 07:45 PM
ZRXGreen's Avatar
ZRXGreen
BLUE1972, what is that and how do you use it?
Old Jan 4, 2019 | 07:50 PM
nutsy's Avatar
nutsy
wonder it it goes between belt sides
Old Jan 4, 2019 | 07:54 PM
ZRXGreen's Avatar
ZRXGreen
The more I look at it, the more it looks like an adjustable brace, correct?
To Squealing belt
BLUE1972's Avatar
BLUE1972
Originally sold by JC Whitney / Sears ..etc - still on E Bay, It goes between the pulleys and as you turn the nut by hand it expands, pushing the accessary to the correct position - then tighten the bolts, They came with different length inserts.
No more pry bars and trying to tighten the bolts while holding the bar.
Old Jan 4, 2019 | 08:14 PM
BLUE1972's Avatar
BLUE1972
  • Called a belt tensioner jack. Amazon has them. $38.00 MSC = $22.00
    the length is not as long as I would like but you could make an extension , the compressor is the one to worry about. The rest it should fit with no issues.
Old Jan 4, 2019 | 08:18 PM
PureJoy's Avatar
PureJoy
I'm not questioning the OP, but is there ever a chance it could be an actual pulley bearing??
