Squealing belt
Old Jan 4, 2019 | 09:03 PM
alivenkicken's Avatar
alivenkicken
Good bet it is! Probably the A/C pulley bearing.
Old Jan 4, 2019 | 09:40 PM
71 Green 454's Avatar
71 Green 454
Originally Posted by nutsy
yes, it’s a pain to tighten, had to put on ramps and do it from the bottom, that was the one squealing, all good now.
Hey nutsy, does yours still have the idler pulley for the crank to water pump belt?
Old Jan 4, 2019 | 10:28 PM
jeffwebley's Avatar
jeffwebley
Something that you may also want to check is if the pullies are worn in a u shape, u don't fit v well.
Old Jan 5, 2019 | 06:15 AM
nutsy's Avatar
nutsy
I just checked, its all there but there is no belt on them. is this a backup for the water pump?
Old Jan 5, 2019 | 08:40 AM
71 Green 454
It's an important belt to drive the water pump. Without that belt, the power steering belt is driving everything....PS, Alt., & Compressor.
I wouldn't drive mine without that belt installed.
There are several threads concerning the rear belt, size, and how to install.
Old Jan 5, 2019 | 09:11 AM
nutsy's Avatar
nutsy
thanks Green, didn't know that. I will have to see if I can find these posts about it. maybe that's why I still get a little squeal when I rev engine high. looks like maybe all the belts have to come off to install it.
Old Jan 5, 2019 | 09:50 AM
71 Green 454
BTW, the BB's with A/C has the idler pulley, without A/C doesn't.
Yes, they all come off. You'll find that many of us will remove the water pump pulley, put the belt on the crank, then the wp pulley and get it onto the wp studs.
https://www.corvetteforum.com/forums...hats-this.html
https://www.corvetteforum.com/forums...-come-off.html
Originally Posted by 530planeman
Remove all the belts ,remove nuts and washers on fan to water pump ,put short belt on crank pulley then pull up on water pump pulley and slide over studs on water pump.These belts are so short they don't stretch much .Make sure studs on water pump are not too long as it will be difficult to get pulley over and spin engine over a little to center water pump pulley before final tighten
Now that I have confused you have fun.
Wes
Old Jan 5, 2019 | 12:03 PM
nutsy's Avatar
nutsy
thanks 71 Green.
